Brake caliper slider pin options (NA)?
Posted: Sat May 19, 2018 1:04 pm
by Hoolio
There is a fair bit of clearance between my slider pins and the hole on the bracket. Which part tends to wear, the pin or the bracket? (i.e. if I replace the pins, how much improvement can I expect?) Pins are cheap, brackets are expensive. Are there any upgrade options, or is the only option OE?
This is on my race car. The calipers are sliding freely but there is a lot of taper wear on the pads and a better fitting slider pin would help.
Re: Brake caliper slider pin options (NA)?
Posted: Sat May 19, 2018 5:22 pm
by StillIC
I had your exact problem with my na6 calipers, plus some clunking from the calipers. After purchasing brand new slider pins I found them to be the same diameter as my old pins and made no difference. I bought a pair of second hand brackets which solved my problems. It seems to be the bracket that wears, unfortunately.
Posted: Sat May 19, 2018 9:45 pm
by greenMachine
Isn't there a rubber(?) sleeve inside the largest hole, that the pin slides in? Maybe needs replacing?
Posted: Sat May 19, 2018 10:10 pm
by Hoolio
greenMachine wrote:Isn't there a rubber(?) sleeve inside the largest hole, that the pin slides in? Maybe needs replacing?
The smaller pin runs in a rubber sleeve, which appears to be in good condition.
It's the larger pin which I am asking about. It runs directly in the hole in the bracket, so it's the one which determines now much play there is in the overall assembly.
Posted: Mon May 21, 2018 7:54 am
by StillIC
The big pin has a seal, from memory, but it basically coated steel pin, grease and drilled steel hole that does the bearing of load.
Posted: Mon May 21, 2018 9:53 am
by greenMachine
OK, I stand corrected. Carry on as before ...
Posted: Mon May 28, 2018 11:00 pm
by takai
On a lot of the performance BMWs they tend to use a bronze bushing for the caliper pin to slide on.
https://blog.ecstuning.com/2017/06/08/b ... tallation/Could be an option, if anyone makes them
