Coilovers
wasp47
Coilovers
Postby wasp47 » Thu Apr 26, 2018 11:20 am
Hi
After a lot of research I have ordered a set of V-Maxx xxtreme coil overs for my SE.
They appear to be good value for money and recommended by FM.
They cost me $800 landed from Germany. BC's are $1250 ,with GAZ out of the UK I would have to pay import duty and GST,I asked them to make two packages but they would not.
Will give my opinion when they are fitted.
Steven
Re: Coilovers
Postby KevGoat » Thu Apr 26, 2018 12:50 pm
Did you go the Classic or adjustable?
wasp47
Re: Coilovers
Postby wasp47 » Thu Apr 26, 2018 3:58 pm
Hi Kevin
I bought the adjustable ones
Re: Coilovers
Postby KevGoat » Thu Apr 26, 2018 5:16 pm
That is a good price then, much cheaper than from FM. From the FM site I'm guessing these are the 391/258 lb/in springs (roughly 7kg/4.5kg). I'll be very interested in your thoughts once you've dríven on them for a while.
hellyeah
Re: Coilovers
Postby hellyeah » Fri Apr 27, 2018 11:38 am
Yeh, I'm also interested to hear how these go.
wasp47
Re: Coilovers
Postby wasp47 » Wed May 02, 2018 5:09 pm
Have the rears in ,easy! A problem removing the passengers front, the two nuts holding the hat have rounded and will not budge! :twisted:
Re: Coilovers
Postby KevGoat » Wed May 02, 2018 7:50 pm
wasp47 wrote:the two nuts holding the hat have rounded and will not budge! :twisted:
You need some of these bolt grip sockets, have saved me plenty of drama removing rounded or damaged nuts/bolts over the years ...
Re: Coilovers
Postby NitroDann » Wed May 02, 2018 8:33 pm
Regular 6 flats sockets will probably do the job too.
greenMachine
Re: Coilovers
Postby greenMachine » Wed May 02, 2018 10:02 pm
NitroDann wrote:Regular 6 flats sockets will probably do the job too.
KevGoat wrote:You need some of these bolt grip sockets, have saved me plenty of drama removing rounded or damaged nuts/bolts over the years ...
Wuzzes! Angle grinder FTW!
:mrgreen:
hellyeah
Re: Coilovers
Postby hellyeah » Wed May 16, 2018 3:58 pm
ManiacLachy
Engaged
Re: Coilovers
Postby ManiacLachy » Wed May 16, 2018 4:24 pm
I'm curious too, but didn't want to derail the For Sale thread.
Not to your liking?
Re: Coilovers
Postby KevGoat » Wed May 16, 2018 7:34 pm
Same here ...
OMX542
Re: Coilovers
Postby OMX542 » Sun May 27, 2018 8:22 pm
Can the OP please update this thread on his opinion on these coilovers?
I tried to purchase a set a week or so ago from the same eBay seller, only to have them rejected by customs and returned to Germany (apparently the seller's paperwork was incorrect or insufficient).
Now I'm wondering whether I should take it as a sign and just go yellowspeed next time I find a 10% off coupon...
Re: Coilovers
Postby KevGoat » Sun May 27, 2018 9:44 pm
What sort of opinion can be formed from 100kms?? Take longer for them to settle before adjusting and a decent wheel alignment to suit ...
wasp47
Re: Coilovers
Postby wasp47 » Mon May 28, 2018 7:47 am
Hi
I only had them on for short time, the new owner asked for the factory suspension to be put back on, my initial opinion is that they are excellent, IMO far better than the other well known brand of coilover they replaced.
Steven
