NC trackday coilovers
- Custardtart
Any recommendations for trackday coilovers and anti roll bars for an NC?
Budget is under $2k (Ohlins are too exy) and would ideally like dyno sheets and ali construction.
Would also appreciate thoughts on spring and roll bar rates and camber set up for running R compound tyres.
Any help on where to buy from would be good. Don’t mind shipping in from abroad.
Thanks in advance.
Thanks in advance.
NC1 - 2.5 opposite lock device
Lakeside 62.3
Lakeside 62.3
- JBT
Re: NC trackday coilovers
Tein Flex Z is probably all you need. Whiteline adjustable sway bars are OK but probably overkill with the Tein set-up. I kept the sway bars on mine but, had them on with the stock springs/shocks before getting the Teins.
I know you said the budget was sub $2k but I recently fitted a set of MCA Race Prime (Red) to my 2006 NC and am very happy with the performance.
Only one outing so far at Wakefield and the Eastern Creek this weekend.
This is a track car only.
- NitroDann
I don't have a lot of experience with NC's so when our shop was tasked with preparing Peter Barnwells NC for trackdays I asked everyone I trusted. The people I asked have owned dozens and dozens of race NC's between them and absolutely everyone said to get the Yellowspeed Comp coilovers with the race spring rates (which I cannot remember, might have been 14/11 or similar). Every single person said to use them along with OEM swaybars, the combo has proven to be quick and extremely easy to drive fast.
- Custardtart
Thanks for the replies. I’m going to be doing some sprints and hillclimbs across qld and nsw, I’ll post a thread on progress in Garage Chat.
Hmmm MCA race is a tad over budget but I’ve heard they do a lot to help with set up?
Dann, YellowSpeed looks good, they recommend having a chat about spring rates but off the shelf track rates are around what you mentioned.
I had a look at the Teins but tbh they are a good price but don’t hit the spec I’ve got budget for.
There’s mountains of info in Na/nb set ups but the nc has probably only just come into a reasonable price point for modding so not so much info around. Appreciate your help.
Sway bars seem hugely expensive and I want to make sure I match them up with the spring rates. Can anyone recommend sizes? Is it the same as the NA where you leave the rear stock (generally speaking)?
Lakeside 62.3
Lakeside 62.3
- NitroDann
We bought adjustable whitelines, I cannot remember the size the owner requested, but again, we were repeatedly told to use the big rate coilovers and stock swaybars, afterall, the swaybars only help to tune the balance mid corner against the springs. With enough spring there is no issue with body roll.
So we ran the big rate yellowspeeds and stock swaybars and everyone who has dríven it thinks its a blast thats very confidence inspiring to drive.
Peter always talks about how the car just allows him to drive around a lot of people. he isn't being arrogant about how quick he/the car is, just that it's so unchallenging to drive quick and that it works really well.
- Custardtart
NitroDann wrote: it's so unchallenging to drive quick and that it works really well.
This sums up the difference between the NC and earlier models I think
Lakeside 62.3
Lakeside 62.3
So, which ones were purchased Custardtart?
This thread makes me want the Yellowspeed Comps (if the price is right). What do they go for and where can I get some?
I have been watching the MCA's too, they look the goods as well.
The price difference between the Yellowspeed comps and the MCA Race Prime is not as far apart as you may think.
If I remember correctly I paid around $2600 for the MCA and the Yellowspeed were around the $2200 mark.
I am running the Race Prime with (12kg / 6kg) and am getting some good times and the car is nice and neutral on the stock sway bars.
Doing 1:10's at Wakefield and 1:04's at SMP-south.
- Custardtart
It’s been an interesting journey! What I’ve found backs up Dann’s posts and Snowmotions above in that to see any real time benefit on track the NC needs uber stiff springs.
My car is daily dríven by Mrs Tart so I can’t go to that extreme!
I will probably go with a softer coilover set up at some point to at least get some adjustability. It’s interesting to hear The stock sway bars give a neutral handling NC. I’ve just taken off the RX8 front sway bar and if that helps reduce the understeer I’ll be sticking with the Bilstein/Eibach set up for a bit longer.
It’s a great compromise set up - and I have a spare set of springs/shock for sale if anyone’s interested
Lakeside 62.3
Lakeside 62.3
- Vehicle: Non MX-5
$2200 for YSR? wowzers. I paid $1300 for mine new. Where yours some high end race varient?
project.r.racing wrote:$2200 for YSR? wowzers. I paid $1300 for mine new. Where yours some high end race varient?
Yes, that was the quoted price for the YSR Race coil overs.
The street versions are much cheaper but for a full time track car I saw little point going down that path.
Custardtart wrote:It’s been an interesting journey! What I’ve found backs up Dann’s posts and Snowmotions above in that to see any real time benefit on track the NC needs uber stiff springs.
However, if the track is smooth then stiff yes, however on a bumpy track like Morgan Park too stiff will cause other handling issues as instead of absorbing bumps it will transmit the bump into the chassis. Sometimes stiff is not the best...
- Custardtart
Magpie wrote:Custardtart wrote:It’s been an interesting journey! What I’ve found backs up Dann’s posts and Snowmotions above in that to see any real time benefit on track the NC needs uber stiff springs.
Would the shock adjustment help deal with the bump issues or do you think you’d need a spring change?
If you changed springs, would you need to re-valve the shocks?!!!
Oh dear, I may have opened a can of expensive worms
Lakeside 62.3
Lakeside 62.3
You could have a set of springs for each track but that is going too far. Pick a compromise and play with the settings on the damper
I have about 5 sets of springs at home
