SE spring perch height
wasp47
Postby wasp47 » Thu Apr 12, 2018 12:17 pm
Hi
Do the SE Bilsteins have a different spring perch height from the NB.
Steven
ManiacLachy
Re: SE spring perch height
Postby ManiacLachy » Thu Apr 12, 2018 1:47 pm
They're different shock and coil assemblies completely. Different springs and different dampers with different valving.
I couldn't tell you if the perch height is different though, if you're wondering about spring length?
ManiacLachy
Postby ManiacLachy » Fri Apr 13, 2018 8:56 am
Hey Steven, it just occurred to me that I have my old set of SE shocks on the shelf in the garage. If you let me know where you want measurements taken from I can check it out this weekend. I can't measure the unbound spring height as they are assembled, but I can measure say top hat to perch, perch to bottom bolt, overall length, etc.
wasp47
Postby wasp47 » Fri Apr 13, 2018 12:48 pm
Another silly question
The two studs in the top suspension mounts that go up through the body, are they welded on or splined.
Steven
Postby hks_kansei » Fri Apr 13, 2018 1:18 pm
Splined if I recall. (if you look from underneath you can see the flat head on them to stop them pulling through.
However, the top perch is welded on (or bonded in some other way that doesnt allow for removal without damage), and does not allow for enough room to press the studs out.
Users browsing this forum: No registered users and 47 guests
