EOI: (Mini Group Buy) SADfab MR2-S rear hubs for Miata
Posted: Mon Apr 09, 2018 2:22 pm
SADfab from MT.net are having a Group Buy on MR-2-S rear hubs for NA/NBs.
"We are now offering MR2 hubs ready to go for Miata. What is this you ask?
Its well known the miata hubs leave a few things to be desired. The rears have been known to shear off and break in extreme cases and you end up losing a wheel, damaging your mobile hair salon and ruining your track day at best, or killing someone at worst.
Credit to GeneSplicer for discovering that the toyota MR2-S hub from 2000-05 will fit with some modifications. They are 4x100 pattern, use the same stud thread pitch and length as a factory miata hub, and are substantially thicker with much more desirable machining radii and therefor should be much stronger. This may be the last time you replace the rear hubs as a preventative safety measure!
Price will be $165 shipped for a pair, ready to go including the required washers, with standard studs. We will offer ARP studs and new replacement bearings as an add on option. Price TBA"
For details see:
https://www.miataturbo.net/miata-parts-sale-trade-5/sadfab-mr2-s-rear-hubs-miata-96576/
And:
https://www.miataturbo.net/race-prep-75/mr-s-rear-hub-discussion-94420/
To save on S&H, ManiacLachy & I are interested in getting a set of these.
To keep the mini-Group Buy under the A$1,000 Duty limit and save on International S&H, if 2 other people from SE QLD are interested in "getting in on this action", please add yourself to the list below so that we can place the order ASAP.
Note: There are a few options available in the Group Buy (see first link above) and we can work out the details of what's required when the order is placed.
SE QLD Group 1:
1. Lokiel (nominated purchaser)
2. ManiacLachy
3.
4.
If there are more than 2 others from SE QLD interested, or other locations want them, please add yourself and location to a new group list. Someone from each group will then need to be responsible for placing and receiving the order (this gets around the issue of an individual being prosecuted as an importer for importing too much specific product).
For details see:
And:
SE QLD Group 1:
2. ManiacLachy
3.
4.
