NB8B Rear wheel bearings
ianoz
Postby ianoz » Sun Mar 04, 2018 3:34 pm
after many many stuggles with half shafts frozen in hubs I'm finally ready to replace the wheel bearings :roll:
Have shiny new ones from Mania ready to go in, but realised they have different seals - one side is metal, other is rubber. The ones that came out were metal on both.
Can anyone advise which side should be 'inside' the hub?
I assume it's metal side in so the hub seal has a surface to run on, and rubber out towards the wheel hub - but i've got a 50% chance of being wrong... or knowing me 100%..
NA6 '89 red, NB8B '01 silver
RS2000
Re: NB8B Rear wheel bearings
Postby RS2000 » Sun Mar 04, 2018 6:19 pm
Factory manual says install with the silver coloured oil seal on the inside.
ianoz
Postby ianoz » Sun Mar 04, 2018 6:24 pm
thank you :D
the manuals i referred to just said “press bearing into hub”
RS2000
Postby RS2000 » Mon Mar 05, 2018 9:06 am
Not a good manual! Actually the bearing is pressed into the knuckle, then the hub is pressed into the bearing.
I downloaded the factory manuals, or maybe found a link to them, from somewhere on this forum.
