NA8 Front Brake pads loose in caliper.
Red_Bullet
Vehicle: NA8 - Supercharged
Postby Red_Bullet » Sun Jan 07, 2018 2:00 pm
I just put some new pads in my NA8 and noticed they are quite a loose fit in the caliper. If you lever them with a screw driver they move about 1 to 1.5 mm up or down. On my NB8B (road pads) I tried the same test and found they only move about 0.5 mm.
I compared dimensions of the old pads (Hawk Blue 9012) with the new pads (PFC-11) and found the hawks to be about 0.2 mm longer in total length. Internal shoulder to shoulder dimension they were pretty similar dimensions. I'm a bit concerned because it would not be a pretty scenario if a pad could dislodge from the caliper under heavy loading. It's probably ok though. Thinking about it some I considered linear expansion due to temperature. It seems with a 900 degree Farenheit temperature change they would expand in length from 102.7 to 103.36 mm. There would still be about .5 to .6 mm free play at this temperature. I guess nobody wants pads to jam in the caliper but the amount of free play does seem a bit excessive to me.
Has anybody else noticed this large clearance of pad to caliper?
ImageIMG_20180107_121336 by Keith Wade, on Flickr
ImageIMG_20180107_105851 by Keith Wade, on Flickr
ImageIMG_20180107_105819 by Keith Wade, on Flickr
ImageIMG_20180107_105753 by Keith Wade, on Flickr
Hoolio
Re: NA8 Front Brake pads loose in caliper.
Postby Hoolio » Mon Jan 08, 2018 1:42 am
I can't see any issue with that much clearance. The pad can't come out, and while braking will always be pushed against one end anyway.
Slightly off topic, but I would be interested to know where you bought the PFC pads and how much you paid as I'm thinking of changing to the same.
Postby manga_blue » Mon Jan 08, 2018 6:46 am
Mine have always been about that loose. The only time you'll notice it is when you brake in reverse you may hear a click when a pad slides to the other end of a caliper. Other than that they work fine.
Red_Bullet
Postby Red_Bullet » Tue Jan 09, 2018 7:23 pm
Thanks for the reassurance guys.
Users browsing this forum: No registered users and 29 guests
