Spring spacer thickness
Minimum Chips
Postby Minimum Chips » Sun Jun 25, 2017 6:58 pm
Hi, I want to raise my Clubman 12-13mm on the drivers side at the front and back to match the height of the other side. I want to keep the car completely stock. What thickness spacer/shim will I require in between the springs and chassis. I'm guessing about 5mm thick? Rubber ok to use? Ta
Minimum Chips
Re: Spring spacer thickness
Postby Minimum Chips » Sun Jun 25, 2017 10:51 pm
I mean Top mount spacers. Thanks
StillIC
Postby StillIC » Mon Jun 26, 2017 12:24 am
Front motion ratio (spring bush to ball joint on the A arm) is about 0.76:1. So you will need about 9mm of spacer.
Rear motion ratio (spring bush to outer joint on arm) is about 0.8:1. But the spring is mounted at an angle to the arm (about 17 degrees depending on ride height). So overall motion ratio is about 0.76 once the cosine of the angle is considered. Same again.
Minimum Chips
Postby Minimum Chips » Mon Jun 26, 2017 12:52 am
About 9mm front and back - thanks for that.
Spacer rings made of hard rubber ok to use, or maybe nylon bread cutting board material would be better?
greenMachine
Postby greenMachine » Mon Jun 26, 2017 2:56 am
Say what?!
You want to raise one SIDE but not the other?!
Maybe you might want to investigate a bit further, and see why one side is higher ... or the other lower? Broken springs? Springs not properly seated? Bent suspension? Different springs? Bent chassis? Busted shock(s)?
I don't recall seeing anyone else having a similar problem (but that might just be faulty memory), my feeling is that this is pretty unusual and warrants investigation as to the cause before settling on a solution.
Good luck!
:mrgreen:
Minimum Chips
Postby Minimum Chips » Mon Jun 26, 2017 9:00 am
Stock bilsteins and springs all good. Nothing obviously bent apart from a dent in the chassis rail on the drivers side (could that be the reason?) Drives and handles as it should so not too worried about it.
Postby 93_Clubman » Mon Jun 26, 2017 11:07 am
Front driver side sitting lower isn't usual, but rear driver side sitting lower by 10-15mm is very common on the NA8, whether standard NA8 or NA8 Clubman. It's been discussed a few times on here, but not for a few years: http://w.mx5cartalk.com/forum/viewtopic ... =3&t=59880
greenMachine
Postby greenMachine » Mon Jun 26, 2017 10:24 pm
93_Clubman wrote:Front driver side sitting lower isn't usual, but rear driver side sitting lower by 10-15mm is very common on the NA8, whether standard NA8 or NA8 Clubman. It's been discussed a few times on here, but not for a few years: http://w.mx5cartalk.com/forum/viewtopic ... =3&t=59880
Thanks for that - you learn something new every day! 8)
:mrgreen:
Users browsing this forum: No registered users and 40 guests
