205/50/15 Wheel widths
Posted: Sun May 28, 2017 8:01 pm
Most of this year comments have been made that the best tyre combination for a MX5 iwith 205/50/15's is on a 8" rim. Interestingly Ken at Accurate Suspension mentioned that a 7.5" would be the best choice.
Whilst on the subject of Accurate Suspension comments Ken looked over my tyre data and agreed that the AR-1's temps/pressures were about right. Why so high, well it is because they are on 6.5" rims, wider rims would require less pressure...
Back on topic, These pictures make it plainly obvious that a 205/50/15 on a 8" rim will provide some extra grip in corners. The AD08R's do look a little stretched on 8" rims, however there is almost an extra 25mm of lateral contact patch for each wheel over the 6.5's. Will be interesting to test the 8" against the 6.5's at Norwell.
Stacked 4 high
205/50/15 x 8.0" - 945mm (AD08R's)
205/50/15 x 7.0" - 875mm (AD08R's)
205/50/15 x 6.5" - 842mm (AR-1's)
AR-1's on 6.5" rims
AD08R's on 7.0" rims
Stacked 4 high
AR-1's on 6.5" rims
