New Product: 5x Racing 14mm Rear Sway Bar
Postby Lokiel » Wed Dec 21, 2016 9:14 am
The MSM/SE's 14mm rear sway bar is one of the best for track work but is hard to find since it's specific to the MSM/SE and there aren't many of those around.
5x Racing now have an adjustable 14mm Rear Sway Bar: http://www.good-win-racing.com/Mazda-Performance-Part/61-1768.html?mv_source=News1
From that link:
"Sean's Notes: This is the sway bar to have for going fast at the track. The 14mm rear sway pairs perfectly with the very popular Racing Beat tubular front sway bar. Unlike the factory Mazdaspeed bar, the 5x Racing unit is 3 position adjustable to give you ability to fine tune the balance of your car. In terms of stiffness, the rear most position on the sway bar is slightly stiffer than stock, the center position is a match for the Mazdaspeed 14mm and the forward most position is slightly stiffer than the OEM Mazdaspeed unit."
