'Falling rate' rear sway bar.....
StillIC
Postby StillIC » Tue Dec 13, 2016 6:05 pm
~1kg/mm sway bar with ~1kg/mm tension springs as end links. When tension spring preload is overcome the assembly falls from a ~1kg/mm to a ~0.5kg/mm sway bar. This is the equivalent of going from a 12mm to a 10mm bar diameter.
Re: 'Falling rate' rear sway bar.....
Postby NitroDann » Tue Dec 13, 2016 6:53 pm
Put a gopro on it and do some laps, I need a good laugh.
:D
Cus
Postby Cus » Tue Dec 13, 2016 7:23 pm
My troll-o-meter is going off the scale, but I'll bite anyway:
Wouldn't you be better off with a rising-rate sway bar?
Postby Magpie » Tue Dec 13, 2016 7:37 pm
Why has nobody thought of this yet... Will make blade adjustable sway bars redundant... I want this, does it come in black?
Postby Okibi » Tue Dec 13, 2016 11:06 pm
So that's what they mean by Axle Tramp?
project.r.racing
Postby project.r.racing » Wed Dec 14, 2016 8:40 am
I have subscribed to the thread and have popcorn at the popcorn ready. This is gonna get interesting. :lol:
StanTheMan
Postby StanTheMan » Wed Dec 14, 2016 10:46 am
Cus wrote:My troll-o-meter is going off the scale, but I'll bite anyway:
well from what I recall most of the racers take the rear sway bar out. This could be to compensate that. Bit of spring is better than none....right?
Purecaboos
Postby Purecaboos » Wed Dec 14, 2016 10:50 am
I had to look at the picture in full size to see what was so special. That looks like an old bed spring, should work really well in that application.
rascal
Postby rascal » Wed Dec 14, 2016 11:20 am
StanTheMan wrote:well from what I recall some of the racers who fit mismatched spring combos take the rear sway bar out to make up for the mismatched springs.
FTFY
StillIC
Postby StillIC » Wed Dec 14, 2016 10:43 pm
StanTheMan wrote:well from what I recall most of the racers take the rear sway bar out. This could be to compensate that. Bit of spring is better than none....right?
So, firstly, congrats to STM on having some insight as to why I (or anyone) would do such a thing as to create a falling rate sway bar.
My aim was not to create a falling rate bar but to build a softer bar than is available off the shelf. My 12mm bar makes my car too tail happy, and without the bar attached Guran reports that I am cornering on three wheels (picking up the inside front wheel). So I need something stiffer than zero bar, and something softer than a 12mm bar. If I had an 11mm bar I would try it, but it is almost (75%) as stiff as a 12mm bar in any case. So, for ~$10 worth of Century springs I rigged up what I have shown in the photo to halve the bar rate. Problem is that tension springs have some inbuilt preload, about 8kg in the case of the springs I have used, which equates to about 8mm deflection in the sway bar. Not ideal, but for the small price worth experimenting with I reckon.
I haven't tried them on the track, but on the road it is difficult to tell the difference between the 12mm bar and the above assembly. Probably because my 165/75 R13 Supercats can't generate enough lateral grip to really roll the car enough to engage the secondary springs by a significant amount. But warm A050s certainly will.
Having thought about the falling rate sway bar concept I figure that the higher initial rate will keep the car responsive, but the later softer rate will increase grip at that end of the car during hard cornering and restore balance. Time will tell.
plohl
Postby plohl » Thu Dec 15, 2016 12:19 am
Why didn't you just drop the rear, or increase front spring stiffness?
Was it simply because this was a cheap and easy option?
plohl
pepejesus
Postby pepejesus » Thu Dec 15, 2016 2:35 am
StillIC wrote:...my 165/75 R13 Supercats can't generate enough lateral grip to really roll the car enough to engage the secondary springs by a significant amount. But warm A050s certainly will.
What kind of set up are you running that requires a softer than 11mm rear bar with A050s? Seems a bit odd.
2004 SE - stock ECU, stock engine, BEGi intake, FMIC, BC Racing 10/6, 15x8s, 225/45 NT-01s
Barbagallo long: 70.488
Barbagallo short: 58.999
StillIC
Postby StillIC » Thu Dec 15, 2016 7:45 am
plohl wrote:Why didn't you just drop the rear, or increase front spring stiffness?
Partly. I have a mortgage, family, job, hobby...time and cash can both be in short supply sometimes, and swapping out springs is a PITA compared to taking out sway bar links. Plus, I am really fine tuning now...down to plus or minus 0.5kg/mm in roll. Springs are only obtainable in 1kg/mm increments and are more expensive. It only cost me $10 plus an hour or so of time to do this.
StillIC
Postby StillIC » Thu Dec 15, 2016 7:54 am
My springs are nominally 7 kg/mm front and 6kg/mm rear (Teins), which is softer at the front than most racers I know use, but typical to firm for the back. (Edit: I should add that all springs are backed up by tender springs which activate on the inside of the car during roll.)
I have a Racing Beat thin wall hollow front bar, which is as stiff as a one inch solid bar, to compensate the soft front springs in roll. As camber settings have changed, as well as some height adjustment, I have been oscillating between a 12mm rear bar and none at all. I think I have been oscillating around the ideal rear roll rate for all setups and am now finally getting around to doing something about it.
I'd be happy to run no rear bar at all if I wasn't picking up a front wheel. Of interest, Gordon Murray, famed Formula 1 and McLaren F1 designer, didn't run rear sway bars on his cars.
The American
Postby The American » Thu Dec 15, 2016 9:57 am
If the left and right were not connected and reliant on each other , this might work a little. However, I don't think it would take much for the side under compression (the inside) to simply bulge and pop out, leaving the bar to suddenly change tension mid corner.
