Stiffness of OEM v/s aftermarket swaybars
tiw
Postby tiw » Tue Dec 06, 2016 11:17 am
Does anyone know how a front NB Whiteline swaybar on the outermost hole (less stiff) setting compares to the standard OEM?
On this setting is it more stiff than the OEM?
Thanks
Re: Stiffness of OEM v/s aftermarket swaybars
Postby Magpie » Tue Dec 06, 2016 11:55 am
The further away from the sway bar the softer.
What thickness is the whiteline sway bar? Depending on the model it could be 24mm with 2 holes.
Could be wrong but the OEM for a NB is 22mm. If not wrong the 2 hole Whiteline sway bar (set on hard) would be 67% stiffer than OEM and on 'soft' 42% stiffer
RS2000
Postby RS2000 » Tue Dec 06, 2016 12:34 pm
Yes, 24mm Whiteline, on softest setting, definitely stiffer than 22mm oem
tiw
Postby tiw » Tue Dec 06, 2016 12:49 pm
Thanks,
Just what I needed.
Users browsing this forum: No registered users and 158 guests
