Hi all
Just chasing a couple of measurements from a standard na & Nb.
Im after the height of either the lowest point of the crossmember on the front and rear subframes to the ground or any other fixed point on the front and rear subframes.
This is for a conversion of mx5 setup into another car and I want to look into the lower arm and suspension geometry at standard height.
thanks in advance
Daniel
NA & NB measurement, front subframe height std
- Learner Driver
- Vehicle: ND - Supercharged
Re: NA & NB measurement, front subframe height std
Phil Bradshaw was after something similar a while back, so it might be in here:
search.php?author_id=13583&sr=posts
If not, will measure as not sure it's in the factory workshop manual.
1993 NA8 32 PSI cold all round:
front subframe (flat area just behind splash guard): 140mm; &
rear subframe (the protruding tab below the alignment bolt): 155mm.
- Learner Driver
Thanks heaps
they will both help a lot!
