NA6 rear sits too high after subframe swap...
Posted: Fri Nov 25, 2016 8:40 pm
Hi all,
First post in the tech section (probably not the last!)
Car is my partners, my background is Nissans (180SX x 2, 84 300ZX, 89 300ZX TT etc)
Long story short, handbrake failed and NA6 rolled down steep driveway, hit a low wall, caught exhaust tip and pushed muffler into subframe...
Weirdly enough, bent the subframe, pushing the right rear wheel into the wheel arch, but the arms ended up being fine.
Swapped to an NB subframe, but re-used NA upper and lower arms and swaybar links with the NB swaybar and d-bushes.
Went to get an alignment the other day, and he said he couldn't put much, if any, camber on the rear because it's sitting too high. I hadn't noticed but it does seem a bit higher than normal.
Is it due to tightening the bolts (to proper torque spec) whilst the car was still on stands?
I had a jack under the lower arm to raise it up until it lifted off the stands, but presumably this wasn't as compressed as it would be on the ground.
BUT - how are you supposed to get in there with a big torque wrench once it's back on the ground?
I would have thought at the factory torque specs they would still have enough play, but the two alignment guys reckon they both tried to push it down to no avail.
Sooooo... should I be finding a sympathetic mechanic with a hoist that has ramps not swing arms, loosen and try again? Or is the alignment guy not correct here. He suggested 'a set of Kings' but I'd rather find the source than go for a 'solution' like that.
I can attach the alignment readout if that makes any sense...?
Thanks
Thanks
