2001+ Automatic Proportioning feature??
guss_bruss
Postby guss_bruss » Fri Nov 18, 2016 10:49 am
I've been in contact with Flyin' Miata about their Willwood big brake kit with 2 piece rotors, Looking to just upgrade the fronts to willwoods. They have gotten back to me saying that ALL 2001+ ABS equipped Miatas sold in the US had an automatic proportioning feature which means you wouldn't need to run a proportioning valve when running bigger front brakes. They were not sure if this feature is present in AUS model MX-5's
Does anybody know if this Automatic Proportioning feature made it onto AUS model MX5's??
Follow me on social media!
Instagram: @guss_bruss www.instagram.com/guss_bruss
Youtube: http://www.youtube.com/user/angusis2fast4u
RS2000
Re: 2001+ Automatic Proportioning feature??
Postby RS2000 » Fri Nov 18, 2016 4:57 pm
Non ABS models have a proportioning valve, but ABS models don't. I understand the ABS does the proportioning.
guss_bruss
Postby guss_bruss » Sun Nov 20, 2016 12:52 pm
Anyone else able to comment?
Tony
Postby Tony » Sun Nov 20, 2016 1:07 pm
RS2000 wrote:Non ABS models have a proportioning valve, but ABS models don't. I understand the ABS does the proportioning.
Correct.
'09 NC2
smy0003
Postby smy0003 » Sun Nov 20, 2016 1:11 pm
Ask Beavis in his build thread. He just put wilwoods on his Japanese nb8b and put a prop valve in.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
guss_bruss
Postby guss_bruss » Sun Nov 20, 2016 1:37 pm
smy0003 wrote:Ask Beavis in his build thread. He just put wilwoods on his Japanese nb8b and put a prop valve in.
I think he did an ABS delete.
guss_bruss
Postby guss_bruss » Sun Nov 20, 2016 1:39 pm
Correct.
Thanks for confirming that. Do you know if I will or will not need a proportioning valve? I ordered the kit without it as I believe I don't but just wanting to double check.
Luke
Postby Luke » Sun Nov 20, 2016 10:49 pm
All NB8B's here had ABS with EBD.
Funny how people have forgotten what EBD is since the introduction of 500 or so new acronyms from every manufacturer which all stand for some sort stability control system with ABS and EBD.
Electronic Brakeforce Distribution.
It works in conjunction with ABS to provide maximum braking to each wheel under hard braking.
In a NB8B case the 2 fronts are separate and the 2 rears as a single unit since they only have a 3 channel system.
2022 BRZ 10AE
2021 GR Yaris
guss_bruss
Postby guss_bruss » Mon Nov 21, 2016 5:20 pm
Luke wrote:All NB8B's here had ABS with EBD.
Thanks Luke. That sums it up perfectly.
