NA6 & NA8 Brake Servo Vaccum Hose
myredmx5
Postby myredmx5 » Tue Oct 18, 2016 11:17 am
Had no luck getting a replacement hose as this part is no longer available.
Has anyone got any idea of how to remove the old non return valve and insert it into a new vacuum hose.
Re: NA6 & NA8 Brake Servo Vaccum Hose
Postby 93_Clubman » Tue Oct 18, 2016 4:06 pm
Just had a look on my NA8 - removing it by slicing the pipe length-ways shouldn't be too difficult, but trying to insert & manoeuvre it to the mid point of the pipe wouldn't be easy. Heat & lube will get it started - perhaps then it can be left closer to either end rather than going for the mid point.
sailaholic
Postby sailaholic » Thu Oct 20, 2016 11:46 am
I had no luck getting one in when I needed to run a non stock hose.
I went and bought a brass non return valve from my local brake specialist and some vacuum hose and made one up. The brass valve it like any other hose fitting
