NB8B - rear shockers...how much should I be paying? (BNE)
charcoal
Postby charcoal » Thu Aug 18, 2016 1:38 pm
I'm after standard replacement shockers to be supplied and fitted to our NB.
What is a ball park figure - I have been quoted $700 (?)
Thanks
Code4
Re: NB8B - rear shockers...how much should I be paying? (BNE)
Postby Code4 » Thu Aug 18, 2016 3:20 pm
I imported koni replacement oem shocks with new fcm bumpstops and fitted them myself for A $600.00.
Never put the top up unless the storm has a name.
Code4
Postby Code4 » Thu Aug 18, 2016 5:41 pm
That was for four. Took about one hour each corner.
Blesif
Postby Blesif » Thu Aug 18, 2016 10:02 pm
$700? I think not unless you mean supplied and fitted. Even then, it would be pricey. KYB, an excellent Japanese company, make original spec replacements for the MX5 at a fraction of that price. They are called "Excel-G". Look them up. Lots of places stock them as they are a quality product at an affordable price.
Postby manga_blue » Thu Aug 18, 2016 10:36 pm
x2 for KYB Excel-G. Good shocks!
Take care if you're installing them yourself and also worth warning your nmechanic if he/she's doing it. The metal in the centre shaft is quite soft and it's easy to strip the thread on the top centre nut. Better to add a second nut and lock them together rather than tighten the one nut hard.
edit: check them out on ebay - very cheap. If rear shocks are gone on an MX5 then the front shocks are probably stuffed too. It's easier to notice bad shocks at the rear because you're almost sitting on them.
Postby Magpie » Fri Aug 19, 2016 7:30 am
Make sure when you order them that the spring rates are the same as your OEM ones.
charcoal
Postby charcoal » Fri Aug 19, 2016 7:40 am
Thank you guys - that gives me the incentive to shop around.
The $700 figure was for supply and fit two rear shockers.
charcoal
Postby charcoal » Fri Aug 19, 2016 12:18 pm
Thanks for stopping me from making another mistake and paying more than necessary - now having KYB's (thanks Blesif) front & rear for not much more than the price that I was quoted for just the rears.
I will be sure to let the workshop know about the trick when fitting re stripping the thread (cheers manga_blue :D )
Looking forward to the improvement when we use the car next weekend.
Blesif
Postby Blesif » Sun Aug 21, 2016 7:30 pm
Good one Charcoal. Enjoy. Manga Blue, give my love to Moruya, I lived there for 18 months. Nice town.
