Soft Brake Pedal
Posted: Sat Aug 06, 2016 7:56 pm
by SaM
Ever since i've had my NB8A the brakes have never impressed me. I have bled the brakes about a thousand times, installed braided lines, greased the slide pins, and adjusted rear calipers so they are almost dragging. All of which has resulted in no significant improvement. I have noticed however, with the handbrake applied 30% the pedal feel is improved significantly. Also, when I push the thing that floats inside the master cylinder, black misty stuff comes out.
After all this I think the master cylinder may need replacing, would you blokes agree? Any advice would be appreciated. Currently running QFM HPX Brake Pads
Re: Soft Brake Pedal
Posted: Sat Aug 06, 2016 8:45 pm
by Regie
sounds like the master cylinder or brake booster has a leak, probably a hole in the diaphragm inside. you change them both as a whole anyways
Posted: Sat Aug 06, 2016 10:19 pm
by manga_blue
The seals around the pistons in the master cylinder are deteriorating. That's the black misty stuff you see - perished rubber.
As soon as I see that starting to happen on any car of mine I replace or rebuild the master cylinder. Soft pedal then goes away.
Posted: Sun Aug 07, 2016 1:30 pm
by SaM
Cool cool, this has been helpful. I'll look into a new one/rebuild.
Posted: Sun Aug 07, 2016 2:19 pm
by bruce
On an aside, my gasket around the reservoir cap was deteriorating. This caused misty rubber to dirty my fluid.
