NC suspension
jackdog
NC suspension
Postby jackdog » Sat Jul 23, 2016 6:33 pm
Hi Guys, I just fitted eibach springs & Koni sports to my car and all is good except when I let out the clutch sharply I get a noise like a loose trim plate. I've emptied the boot checked and re checked all nuts and bolts, sway bar ends, the fuel pipe shroud etc. all tools are accounted for, it's fine when coasting and over bumps. Any suggestions as to a culprit? Thx
Charlie Brown
Re: NC suspension
Postby Charlie Brown » Sun Aug 14, 2016 8:57 am
Two areas to check.
Brake slider pins for wear and that they are greased.
Suspension arm bolts. Make sure they are tight. An 1/8th turn on mine eliminated a bad knock.
