Factory bracing on '03 - '05 NB's ?
Code4
Postby Code4 » Wed Apr 20, 2016 10:44 am
Noob question.
I believe '03 - '05 NB's had additional factory bracing. What did they do ?
Never put the top up unless the storm has a name.
Re: Factory bracing on '03 - '05 NB's ?
Postby hks_kansei » Wed Apr 20, 2016 1:24 pm
They allowed Mazda to add a few more dot-points to the spec list in the brochure.
In all seriousness though, from memory the extra bracing was just another couple of braces around the area between the doors (under the car) and a strut brace.
Here's a pic of the underside of an SE (Mazdaspeed Miata since it's a US car)
being an SE it probably has some extra factory braces that the regular ones didnt, but gives you an idea of the OEM braces and locations.
Personally, the strut brace was not much use, I have one on my car and there's no difference. IMO it was just marketing (has a brace there, must be sporty!)
The rest of the bracing I can't speak for
Postby Lokiel » Wed Apr 20, 2016 2:07 pm
If you have, or plan on getting, frame rails, that long vertical brace above the first "o" in "photo" is typically discarded.
Code4
Postby Code4 » Wed Apr 20, 2016 4:53 pm
Thank you for the replies. I seem to have double posted on this but have asked mods to delete one.
Users browsing this forum: No registered users and 75 guests
