Assistance with swapping diff bushes SE Melbourne
davekmoore
Postby davekmoore » Mon Dec 28, 2015 3:13 pm
Anyone able to "assist", bearing in mind my input would be mainly handing over tools and beers?
lightyear
Infinity & Beyond
Re: Assistance with swapping diff bushes SE Melbourne
Postby lightyear » Tue Dec 29, 2015 7:43 am
I did this once. Not a fun job. From memory, I drilled a bazillion holes into the rubber and pulled them out.
You shouldn't need to swap out the OEM ones anyway. My "SE" has all OEM bushes throughout.
I never noticed a difference with them changed.
The American
Postby The American » Tue Dec 29, 2015 8:07 am
I used a puller orientated to 'push' on one side (required a piece of 7x30mm flat bar to spread across the back of the bush for the puller to push on). It was then a case of using a drift to tap on the lip of the bush until it broke free.
The flat bar began to fold itself in half before the bush moved, and I was worried that it was going to break the alloy carrier.
I then installed urethane bushes, and was thence forth able to hear every harmony uttered by my semi slicks. Even with my helmet on.
Postby fastfreddygassit » Tue Dec 29, 2015 5:06 pm
looks like you will have to pay a mechanic for this one! :mrgreen:
davekmoore
Postby davekmoore » Tue Dec 29, 2015 5:57 pm
The American wrote:I then installed urethane bushes, and was thence forth able to hear every harmony uttered by my semi slicks. Even with my helmet on.
Pretty much a track car now anyways.
project.r.racing
Postby project.r.racing » Tue Dec 29, 2015 9:12 pm
Take to them with a blowtorch. Do so in a well ventilated area. They will burn horrible fumes.
cookie
Postby cookie » Wed Dec 30, 2015 1:08 am
You guys are so destructive! I just propped mine up and a few hits with a punch around the outside metal sleeve and they popped out mostly intact.
The American
Postby The American » Wed Dec 30, 2015 7:52 am
cookie wrote:You guys are so destructive! I just propped mine up and a few hits with a punch around the outside metal sleeve and they popped out mostly intact.
That wasn't a Thor Hammer you used with the punch was it?
project.r.racing
Postby project.r.racing » Wed Dec 30, 2015 3:12 pm
If you have seen cookie's arms. You'd know he could life Thor's Hammer. :lol:
Postby Mr Morlock » Mon Jan 04, 2016 11:10 am
ffg has got the right idea- pay the professional.
beavis
Postby beavis » Mon Jan 04, 2016 11:49 am
Dave, seems like you need a jack hammer/air chisel to do it the smart way:
http://www.youtube.com/watch?v=O1LivDxs9GI
http://www.mazda-speed.com/forum2/index ... 487.0.html
