sway bar bracket boo boo x2
Posted: Sun Oct 18, 2015 12:00 am
by GP14
so both my brackets broke after many years of stress. Did some reading and apparently this is common for upgraded suspension components. Has anyone else had this happen to them? I tried to remove the bracket but found that they were spot welded as well as bolted on. Who was the genius who decided that. I will remove them soon but in the meantime will live without the sways till i replace the bracket. Anyway what did you end up replacing it with if the factory brackets are spot welded on?
Re: sway bar bracket boo boo x2
Posted: Sun Oct 18, 2015 3:09 am
by GP14
nevermind found this post from 2012 viewtopic.php?f=30&t=51957
