so both my brackets broke after many years of stress. Did some reading and apparently this is common for upgraded suspension components. Has anyone else had this happen to them? I tried to remove the bracket but found that they were spot welded as well as bolted on. Who was the genius who decided that. I will remove them soon but in the meantime will live without the sways till i replace the bracket. Anyway what did you end up replacing it with if the factory brackets are spot welded on?sway bar bracket boo boo x2
Re: sway bar bracket boo boo x2
nevermind found this post from 2012 viewtopic.php?f=30&t=51957
