NA/NB Front ABS Hubs, 2 Parts Numbers???
Posted: Fri Sep 25, 2015 8:19 pm
I am up for new front Hubs again after only 16 months of the so called "better" re-packed blue printed ones that had the ARP studs. I had grease seeping from these from the 1st track day.
OEM originals lasted from March 2004 to May 2015 with a lot more track days in that time but with original Shocks and Springs.
I am inclined to go with originals again with a bit of Apples and Oranges comparison going on just to compare how I go again.
My problem is that there are 2 Parts Numbers listed for ABS Hubs. Does anyone know the difference between the 2?
I am using Arlington Mazda as an example here but all US Mazda dealers seem to offer the 2 parts numbers for ABS Hubs which are also searchable on Amayama.
NA23-3304-XA LINK
NA23-3304-XC LINK
As far as I can tell they are the same except that everyone wants to charge a lot more for the C Model with no explanation other than they are for 8th January 04 build date onwards???
I thought there were only 2 types of NA/NB front hubs that were identical other than the ABS ring for the ABS model, interchangeable in other words.
And yes I know you can move the ring across from a ABS Hub to a Non-ABS Hub. NA01-33-04XA LINK But I can get the XA ABS model cheaper then the Non-ABS model.
NA23-3304-XA LINK
NA23-3304-XC LINK
