Interchangeability of front wheel bearings
- davekmoore
Are NB8C (in my case an SE) front wheel bearings the same as other NBs, or as NAs for that matter?
- de Bounce
Re: Interchangeability of front wheel bearings
Might be something in this post
http://mx5cartalk.com/forum/viewtopic.php?f=78&t=46157
if you work for a Mazda dealer can't the Spare Parts dept tell you ?
- smy0003
I thought the front bearings were a non-servicable part of the hub assembly?
Sent from my GT-I9505 using Tapatalk
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
- davekmoore
smy0003 wrote:I thought the front bearings were a non-servicable part of the hub assembly?
Are front hub assemblies interchangeable?
Yes, you can change yours with any other NB8B.
- Hellmun
- Vehicle: NB8B - Turbo
NB front wheel hubs can come with out-board or in-board ABS rings. Both physically fit but I had to machine the lip surface to fit the outboard ABS ring last time I got one from America. I'm not sure if it's just model dependant or Market dependant but my NB8B is definitely outboard.
Users browsing this forum: No registered users and 39 guests
