Squealing Sound
lukoo
Squealing Sound
Postby lukoo » Sun Jun 21, 2015 11:43 pm
Hi guys, need some help here.
I am driving a 1992 NA6 and recently I have been hearing this squealing sound during the drive around. It only occurs when the car is moving and it does not matter whether the clutch is engaged or not.
Could it be the bearings? Any ideas and possible solutions?
Re: Squealing Sound
Postby KevGoat » Sun Jun 21, 2015 11:55 pm
Loose fan belt?
But more information needed. Where does the sound come from. Front, rear, gearbox? Under acceleration? Under braking?
Re: Squealing Sound
Postby Magpie » Mon Jun 22, 2015 7:51 am
A guinea pig wrapped in masking tape?
JBT
Re: Squealing Sound
Postby JBT » Mon Jun 22, 2015 9:09 am
Brake wear squealers (wear indicators) :?:
kalt
Re: Squealing Sound
Postby kalt » Mon Jun 22, 2015 7:16 pm
Cross dressing wild boar piglet wearing a tiara and ballroom gown wedged under the car, near the muffler&diff
Owning a fast car is easier than driving a car, fast.
For sale
NB8 Factory Airbox
lizard
Re: Squealing Sound
Postby lizard » Mon Jun 22, 2015 7:22 pm
School boy at a catholic school?
lukoo
Re: Squealing Sound
Postby lukoo » Wed Jun 24, 2015 4:16 am
The sound is from the back of the car. It occurs as long as the car is moving regardless whether whether accelerating or braking.
JBT
Re: Squealing Sound
Postby JBT » Wed Jun 24, 2015 6:29 am
Have you ruled out brake wear squealers (wear indicators) :?:
Re: Squealing Sound
Postby manga_blue » Wed Jun 24, 2015 6:47 am
It's usually either the wear squealers or a small stone jammed between the brake rotor and its backing shield. Wear squealers are steel tabs mounted on the brake pads that drag against the rotors once the pads wear down to minimum depth.
Take the wheel off and check thickness of the pads. If they are not very worn then poke around between the shield and the rotor with a thin screwdriver to see if you can find a stone and dislodge it. It doesn't matter if you bend the shield a little bit, just bend it back into place when you've finished so that none of it drags against the rotor.
AndrewM
Vehicle: ND - Supercharged
Re: Squealing Sound
Postby AndrewM » Wed Jun 24, 2015 11:44 am
Had this coming from the front - turned out to be a small stone - once removed all good again.
1997 NA8 BRG / Tan LE - AMX-597 - SOLD IN 2002
2000 NB8A Twilight Blue - AMX-518 - SOLD IN 2015
lukoo
Re: Squealing Sound
Postby lukoo » Wed Jun 24, 2015 12:26 pm
Thanks! Will check it ASAP.
