Hi guys,
just changed the shocks on a 93 NA8 and after removing the plastic cover under the sump, noticed left rack end (power steering) leaking from boot.
Any one know if there is a repair built thread on this using any seal kit? I know you can repair a power steering pump but I haven't come across PS rack repair process.
Any help would be much appreciated.
Power steering rack is leaking
- Driv3r
2000 NB8A
1993 NA8 (Gone)
1973 BMW 2002Tii Turbo
1993 NA8 (Gone)
- Driv3r
Re: Power steering rack is leaking
2000 NB8A
1993 NA8 (Gone)
1993 NA8 (Gone)
- Vehicle: ND - Turbo
It's certainly possible to rebuild a rack, but I havent done it so can't explain the process.
AS far as the leak goes, i'd just buy a bottle of power steering fluid with the stop-leak additive. It basically works by helping the rubbers seals swell up again and seal better.
The rack on mine has been weeping for something like 7 years now.
I would de-power the rack, it feels like sh*t.
- Driv3r
Thanks M1474 & hks,
Boss is driving the NA8 with auto transmission. Would love to de-power it but she would rather the ps. I heard the stop leak fluid is not a good long run solution as it would eventually damage the seal and get worse. It's only used by second hand car dealerships to hide the leak.
I'm not sure if NB PS rack is compatible with NA8C (JDM import). But I think it's best to just replace it with a compatible second hand. I will post a WTB and wait.
Thanks again for the help, much appreciated.
2000 NB8A
1993 NA8 (Gone)
1993 NA8 (Gone)
Driv3r wrote:I'm not sure if NB PS rack is compatible with NA8C (JDM import).
Apparently not: http://www.miata.net/garage/compatibility.html
Driv3r wrote: ps. I heard the stop leak fluid is not a good long run solution as it would eventually damage the seal and get worse. It's only used by second hand car dealerships to hide the leak.
I'd never use a stop leak engine oil additive, but so far have had no issues with the power steering stuff after 7 odd years.
Granted, the leak on mine isn't that bad, it took about 12 months for the reservour to get to the low mark.
- Driv3r
hks_kansei wrote:Driv3r wrote: ps. I heard the stop leak fluid is not a good long run solution as it would eventually damage the seal and get worse. It's only used by second hand car dealerships to hide the leak.
Yes same here I check the fluid but it hardly goes down, even though you can notice a leak from ps rack and oily pump. Strange ay.
2000 NB8A
1993 NA8 (Gone)
1993 NA8 (Gone)
