Which bushes to change?
Re: Which bushes to change?
Postby hks_kansei » Wed Mar 25, 2015 4:35 pm
The best way is to get under there and have a look at which ones are most worn and replace those ones.
Overall though, on an MX5 it's really just the swaybars, control arms, and diff that have bushes.
I'd do the swaybar ones first, since they're easy and cheap.
Then i'd do the control arms, which are a bit more costly and very annoying (have a press handy, or a good vice and HEAPS of different sized sockets/pipes etc)
Diff bushes aren't worth bothering unless they're obviously stuffed, or you're in there anyway.
The issue with control arms is that you don't really want to do them partially (ie: replace lower arm bushes and leave the uppers)
if you want to do it in stages it's best to do each end (front arms, then rear, or vice versa)
slug_dub
Postby slug_dub » Wed Mar 25, 2015 5:00 pm
If you were going to replace control arm bushes then definitely do all of them, upper and lower, front and rear.
Diff bushes, sway bar bushes, can probably take or leave those.
Steering rack bushes are a possibility for a change too.
Postby NitroDann » Wed Mar 25, 2015 5:45 pm
Postby NitroDann » Wed Mar 25, 2015 6:06 pm
Im making a big 949 order for a street/race build if you want me to grab them for you at the same time and share shipping.
Postby Mr Morlock » Wed Apr 01, 2015 10:35 am
why change anything which is not causing a problem? You can get checks done by Pedders for a low cost.
rascal
Postby rascal » Mon Jan 11, 2016 12:53 pm
Dundy2456 wrote:So, it's time to change the bushes. My car is creaking when I turn and brake so I'm taking that as a good indicator of worn bushes.
Actually a good indicator that they need greasing, not necessarily replacing..
rascal
Postby rascal » Mon Jan 11, 2016 2:10 pm
You'll have to remove the bushings to regrease them. Don't think just spraying on the outside does much if anything..
Energy Suspension recommend 'synthetic, water resistant marine-grade grease' as an alternative to their own brand of grease, so if your grease matches that description then should be fine..
Steampunk
Postby Steampunk » Mon Jan 11, 2016 3:16 pm
Dundy2456 wrote:*digs up old thread*
Can anyone recommend a good place to get this done?
Accurate Suspension at Springwood
Postby Magpie » Mon Jan 11, 2016 3:22 pm
Accurate Suspension at Springwood installed grease nipples in my control arms last time the car was there, well worth it!
