Q about Yellow speed Coilivers
angusis2fast4u
Postby angusis2fast4u » Wed Nov 05, 2014 8:07 pm
So to give some reference I had an NA which I bought completely stock. I put BC BR's in it and was extremely happy with how they improved the handling of the car. I have recently bought an NB which had a set of Yellow speeds installed in it when I purchased it. Now I am finding these yellow speeds terrible... Their rebound is way out and is quite scary when up in the mountains and I also have a question about their dampening adjustment - mine are all the way hard (full clockwise) and they are about as soft as the BC's would go in full soft (full counter-clockwise) is this normal for yellow speeds? And to make things worse it seems as if the rear shocks aren't there. If you push on it the rear will just bounce.. I am quite disappointed so far!
All shocks are about 1 month old and don't look like they are leaking / have any defects.
Please help!
~Angus
2001 Silver NB8B
Past: Grey 1990 Eunos Roadster
zossy1
Re: Q about Yellow speed Coilivers
Postby zossy1 » Wed Nov 05, 2014 9:07 pm
Spring rates?
Sway bar setup front/rear?
Are these the Dynamic Pro Sport or the race version? Are they gen 1 or 2?
Need more info on your setup.
Or you could call Mania and ask for help - they are happy to support their products. I am no huge fan of YSR coilovers but there are plenty on peeps on here who have been able to make them work.
Roadrunner
coyotes after you
Postby Roadrunner » Wed Nov 05, 2014 9:11 pm
That doesn't seem right at all.
Iv got yellowspeeds in an nb and at the factory setting (6 clicks from softest I think) the car pushes down a little but springs straight back up and stops. No bouncing.
Mx5Mania are the dealer for them, maybe stop by and show them.
The original owner may have tried to adjust the height and adjusted/unscrewed the wrong thing??
MeepMeep
angusis2fast4u
Postby angusis2fast4u » Wed Nov 05, 2014 9:40 pm
Roadrunner wrote:That doesn't seem right at all.
That's what I'm thinking
They were bought like a month ago new if that helps other than that I just bought it like this
~Angus
2001 Silver NB8B
Roadrunner
coyotes after you
Postby Roadrunner » Wed Nov 05, 2014 10:04 pm
I'm no expert on coilovers but I believe if you try to adjust the height by moving the collar that the springs sit on this will severely upset rebound etc
MeepMeep
angusis2fast4u
Postby angusis2fast4u » Wed Nov 05, 2014 11:47 pm
Roadrunner wrote:I'm no expert on coilovers but I believe if you try to adjust the height by moving the collar that the springs sit on this will severely upset rebound etc
Yeah that'll effect the preload not height height is the bottom one
~Angus
2001 Silver NB8B
ralt
Postby ralt » Thu Nov 06, 2014 12:52 am
Hi.
I would get them checked by somebody who knows what they are doing. You could try Ken at accurate suspension in woodridge. I think you may have purchased a car with a known bad set of shock absorbers.
sailaholic
Postby sailaholic » Thu Nov 06, 2014 6:48 am
Adjusting the ride height by spring load is the correct way. Adjusting the other one affects your balance between bump and rebound.
project.r.racing
Postby project.r.racing » Thu Nov 06, 2014 10:25 am
ralt wrote:Hi.
if it is bouncing, then it wont be the shock like in a normal sprung car as the coilover springs are too firm for that.
my guess would be the height has been adjusted using the spring feet, and there is very little, if nil preload, and the spring is bouncing on the spring feet with loss of capture.
angusis2fast4u
Postby angusis2fast4u » Thu Nov 06, 2014 11:33 am
project.r.racing wrote:
ralt wrote:Hi.
I'll take them out and check but before I do.. Isn't preload only meant to be wound up to the point where the spring is just captive? (I know people wing them all the way your rift setups but for daily/handling the spring is only meant to just be captive ??
~Angus
2001 Silver NB8B
Postby Magpie » Thu Nov 06, 2014 12:16 pm
Preload is the amount of weight on the spring to get the desired ride height or the correct corner weight.
There are 2 schools of thought on setting up coil overs. One is adjust the preload first (about 2mm once the collar touches the spring) and then adjust the shock length to get the desired ride height or corner weight. The other is to match the length of the shock to the car to ensure you have used all the available travel and the required droop. Then adjust the prelaod to get the desired height/weight.
The only time (if ever) the spring should be uncaptive is at full droop. This can be checked by jacking the car up and looking at the shock.
Another question, what are the spring rates?
angusis2fast4u
Postby angusis2fast4u » Thu Nov 06, 2014 4:21 pm
Magpie wrote:Preload is the amount of weight on the spring to get the desired ride height or the correct corner weight.
Hey magpie thanks for clarifying that for me, I'm not 100% sure on the spring rates man I bought the car as is ( im the same guy who started that "does anybody actually run E85" thread - yes I'm starting this project :P)
I think I might sell the yellow speeds and put that money into MCA's - thoughts magpie??
~Angus
2001 Silver NB8B
Postby Magpie » Thu Nov 06, 2014 4:47 pm
I have not used MCA's so can't comment, however for all reports the MCA's are worth it.
project.r.racing
Postby project.r.racing » Fri Nov 07, 2014 8:12 am
ralt wrote:Hi.
yes. but 1-2mm can mean the difference between wrong and right. the rest magpie has said.
angusis2fast4u
Postby angusis2fast4u » Fri Nov 07, 2014 10:38 pm
Magpie wrote:I have not used MCA's so can't comment, however for all reports the MCA's are worth it.
What Coilovers do you use then Magpie? I just assumed you would be using MCA! haha
~Angus
2001 Silver NB8B
