Rims for light track duty
Roadrunner
coyotes after you
Postby Roadrunner » Mon Nov 03, 2014 5:07 pm
Im looking at picking up a set of rims for my SE to be dedicated track day tyres. Looking at second hand 15inch there's a lot of variances out there.
What width and offset should I be looking at? 7inch wide, +45?
And what rubber would be best suited?
205/50r15?
Would stock NB8A 15's be fine? (doesn't need to be super light at this point in time)
The SE is lowered a bit so don't want crazy wide or offsets that are going to rub.
Main reason for these is cheaper rubber than the 17's to be annihilated on the track :wink:
MeepMeep
noobee
Re: Rims for light track duty
Postby noobee » Mon Nov 03, 2014 5:50 pm
my son has these for sale in Newcastle area
viewtopic.php?f=44&t=65847
Postby manga_blue » Mon Nov 03, 2014 6:36 pm
For light track work 15x6.5s are good enough, cheap and plentiful. They take 205 and 195/50R15s well. Offsets around 28-35mm are best. You just have to make sure they fit around SE brakes before you buy.
Nevyn72
Postby Nevyn72 » Mon Nov 03, 2014 8:18 pm
Roadrunner
coyotes after you
Postby Roadrunner » Mon Nov 03, 2014 11:25 pm
Doesn't ship to Australia as far as I can see. Otherwise there's a few there for $100 a corner new id jump on!
MeepMeep
