Pressure bleeder cap
prolifik
Postby prolifik » Fri Aug 08, 2014 2:40 pm
Hi guys, before I start I just want to point out this is just a project, I have vacuum bleeders and know how to bleed brakes 50 other ways.... Now......
I believe air is escaping from the threads that screw the lid down... What have you guys got or used to seal the master cyl while adding pressure to it?
I'll add pictures ASAP with what I have
CM sport
Re: Pressure bleeder cap
Postby CM sport » Fri Aug 08, 2014 3:03 pm
Thread tape ftw !
prolifik
Postby prolifik » Fri Aug 08, 2014 6:35 pm
I don't think that would work due to it having to hold around 10 psi or so
project.r.racing
Postby project.r.racing » Fri Aug 08, 2014 7:55 pm
10psi is quite low.
but if you have threading issues. then you really need to look at replacing the worn old threaded parts.
prolifik
Postby prolifik » Fri Aug 08, 2014 7:59 pm
I have no issues..... I'm using a pressure bleeder with a modified oem cap.... Just looking for how people seal the master cyl air tight.
CM sport
Postby CM sport » Sat Aug 09, 2014 12:24 am
Thread tape will work as a temp fix for much higher than 10psi.
prolifik
Postby prolifik » Sun Aug 10, 2014 1:39 pm
Ok cool. I'll give it a go
Users browsing this forum: No registered users and 216 guests
