Advice on wheel & tyre set up NB8B
The Green Goblin
Postby The Green Goblin » Sat Aug 02, 2014 1:14 pm
Hey Gents,
read some of the topics found using the search. The car will be used on weekends & track days primarily, im looking at purchasing either the following rims:
1. konig flatouts 15x8+25
2. 6ul's 15x8+36 (gen 4)
both strong & lightweight, i am leaning towards the flatouts as something 'different' + easier on the pocket, i like the look of the rim but the offset seems a little too low? main question is what is the widest tyre spec i can fit under stock guards..i.e. i don't want to roll guards. looked at the goodwin racing site & it said 205/50/15's tyre will plug & play onto the NB with 1.5 neg camber using flatouts, i was hoping to fit 215's onwards but is this realistic?
what are the limitations to tyre size on the nb running stock guards? I will be running semi's also.
cheers.
rascal
Re: Advice on wheel & tyre set up NB8B
Postby rascal » Sat Aug 02, 2014 3:18 pm
The +25 on the flat outs isn't too low, in fact it's almost perfect for track NB with some camber. ( widens track for better cornering, and still fits under std guards)
The +36 on the 949 is more for increasing the potential market than ideal offset.. (ie fits virtually everything, whereas +25 won't unless you have some camber.
205s are a better choice for 8s than any other size.
The Green Goblin
Postby The Green Goblin » Sat Aug 02, 2014 8:54 pm
rascal wrote:The +25 on the flat outs isn't too low, in fact it's almost perfect for track NB with some camber. ( widens track for better cornering, and still fits under std guards)
Fair points.
though, whats the justification that 205's are the better choice? you can fit from 195's to 225's on 8's easily.
ive owned low offset rims in the past on another car & while they looked good & sat further out/wider, there will always be issues with caliper, strut & guard clearances - so i guess you can say i just want to avoid hassles.
sailaholic
Postby sailaholic » Sun Aug 03, 2014 8:43 am
Why not roll the guard lip?
rascal
Postby rascal » Sun Aug 03, 2014 10:25 am
The Green Goblin wrote:
Fair points.
205s on an 8" rim provide a vertical sidewall, neither stretched nor pulled. Provides best cornering response.
I run the +25 15x8 flat outs on my NB with 205 NT01s. No caliper or strut issues whatsoever. And they don't rub on the guard either, though I do have 3deg neg camber, which would help.
mx5002
Postby mx5002 » Sun Aug 03, 2014 12:53 pm
I run the same setup on my nb8b as rascal though with only 2 degree in the front.. (the most I can get atm without modification)
Fits fine and looks great.
My wheels are og axis banzai' 15x8 +25.
You may have to fit braided lines on the front brakes to clear 15's also. (I had to)
GREEN ITB'd NB8B
Marulan 47.01
Wakefield 1.09.64 :D
davekmoore
Postby davekmoore » Sun Aug 03, 2014 1:51 pm
Fitment info here for Konig Dial In 15 x 8s. Info on the same site for the 9s. Other Konigs may have different fitment issues.
http://www.good-win-racing.com/Mazda-Pe ... -1391.html
The Green Goblin
Postby The Green Goblin » Sun Aug 03, 2014 8:22 pm
sailaholic wrote:Why not roll the guard lip?
my preference is not to touch the guards. they rear quarter tends to warp.
The Green Goblin
Postby The Green Goblin » Sun Aug 03, 2014 8:34 pm
thanks rascal + mx5002.. car does look sharp.
do you guys get much inner tread wear with your camber settings? also, have you guys done any guard work?
ive got mixed thoughts to be honest, im thinking if i get 6ul's im not limited to just 205's as i will have more outer room - but how much before i scrub etc - i dont know. anyone with 15x8 6ul's care to share experience.
while the flatout's look tougher i also don't want the wrong attention that dishy wheels & neg camber can get.
davekmoore
Postby davekmoore » Sun Aug 03, 2014 10:22 pm
The Green Goblin wrote:ive got mixed thoughts to be honest, im thinking if i get 6ul's im not limited to just 205's as i will have more outer room
See the link in my post about tyre fitment on Konigs.
rascal
Postby rascal » Mon Aug 04, 2014 12:23 am
The Green Goblin wrote:do you guys get much inner tread wear with your camber settings?
I actually get more outer tread wear than inner that suggests I need more camber than the 3deg I have now, but mine spends all its life running around corners so may differ to your usage..
sailaholic
Postby sailaholic » Mon Aug 04, 2014 9:35 am
Friend has 15 x 8 6ul with 225/45 on a Na with no scrub.
plohl
Postby plohl » Mon Aug 04, 2014 12:42 pm
^he has a guard roll and a bit of camber though
plohl
Users browsing this forum: No registered users and 207 guests
