Camber wear on second hand tyres
Ben MX5
Postby Ben MX5 » Tue Jun 24, 2014 9:07 pm
Hi there,
Thanks to everyone who helped out on this thread viewtopic.php?f=30&t=63552. Since, I've found a cheap set of 15x7 +40 wheels that I like the look of and weigh about the same as the OEM rims and they're being fitted with AD08Rs on Monday. My plan is to keep this set for MX-5 club vic championship rounds. Feel free to let me know if this plan is rubbish - I don't know what I'm talking about but am trying to work it out.
I've also arranged to pick up this second hand set of wheels and tyres:
They're 205/50 R15 Falken Azenis.
I've got a stock NB8C with the maximum negative camber that the adjustors will allow. This is about -1.2 deg per side on the back. The front is assymmetric - one side is about -1 deg, the other side is about -0.3 degree. As an aside does this assymetry suggest a problem - should I be looking in to this?
Is the camber wear on the Falkens going to be a problem? I'm heading to the PIARC sprint practice day this Saturday - would I be better off taking the Falkens or my 205/45 R16 Kumho KU 31s on OEM rims?
Ben
Stock 03 NB on AD08Rs
Broadford 1m 13.0s
Phillip Island 2m 05.2s
Sandown 1m 38.2s
Winton - short 1m 14.7s
Winton - long 1m 49.3s
Calder 1m 17.3s
project.r.racing
Re: Camber wear on second hand tyres
Postby project.r.racing » Tue Jun 24, 2014 9:14 pm
should be fine. the tyre wall will flex and control the contact surface. inner wear doesn't look bad.
Ben MX5
Postby Ben MX5 » Wed Jun 25, 2014 1:46 pm
Thank you. It is good to know.
Broadford 1m 13.0s
Sandown 1m 38.2s
Calder 1m 17.3s
StuwieP
Postby StuwieP » Fri Jun 27, 2014 4:20 pm
is that 1 degree neg one side and half a degree neg the other? or 3/10ths?
Either way, I'd be advising that you get them symmetrical.
I don't think it's necessarily indicative of a problem but why not ask the alignment shop what they think?
Stu
My NA6/SE build
Engine #1 RIP 04/07/2020
