Nb bump stops
vfrpete
Nb bump stops
Postby vfrpete » Tue Jun 10, 2014 7:42 pm
Does anyone know where I can get a set of rear bump stops. I'm changing shockies and have found the rear bump stops are perished. To suit 2001 nb with stock springs. Genuine ones are nil stock in aus. Till August
Thanks
Re: Nb bump stops
Postby Regie » Tue Jun 10, 2014 8:20 pm
Get some fat cat bump stops for the USA. They are much better than the standard ones
Re: Nb bump stops
Postby Magpie » Wed Jun 11, 2014 11:46 am
:BROADY: on the Fat Cat. http://fatcatmotorsports.com/
Are you retaining stock suspension or changing to coilovers?
vfrpete
Re: Nb bump stops
Postby vfrpete » Wed Jun 11, 2014 12:08 pm
Standard suspension, just fitting new shockies
tbro
Re: Nb bump stops
Postby tbro » Wed Jun 11, 2014 6:42 pm
Superpro Falcon ea fronts :)
vfrpete
Re: Nb bump stops
Postby vfrpete » Wed Jun 11, 2014 9:58 pm
So the ea falcon ones fit the back shockies?
Charlie Brown
Re: Nb bump stops
Postby Charlie Brown » Wed Jun 11, 2014 11:04 pm
Fat cat without a doubt.
Front and rear will set you back about $100. Will take about a week to be delivered to your door.
The improvement over my Tein bump stops was noticeable.
Re: Nb bump stops
Postby KevGoat » Wed Jun 11, 2014 11:09 pm
Another vote for Fatcat stops. Made a huge difference on my NA. I should have known better and taken the time to buy a new set for my NB before putting the stock suspension back in ...
Re: Nb bump stops
Postby 93_Clubman » Thu Jun 12, 2014 1:17 pm
Tbro's Superpro Falcon EA fronts sound interesting - there's also a damper boot/bump stop combo for the basic setup:
http://www.mx5parts.co.uk/shock-absorbe ... p-358.html
