15 x8 + 20 offset question
- Vehicle: ND - 2
Hi.
I have the opportunity to buy wheels as above.
The question is will they fit without having to roll the guards and will a 195 50 tyre fit?. If not what do you recommend.
- Vehicle: ND - 2
Re: 15 x8 + 20 offset question
Hi again.
Forgot to advise the model: na
- zossy1
You will need to roll the guards but they will fit fine.
- Vehicle: NB Roadster
its a very common size.
if you google search those specs with "miata mx5" you should fine what your looking for,
otherwise you can also use willtheyfit.com
OR
you can do some old fashioned brain work and measure it.
OR
WINTON PB - 1:57.4000
I have this size and offset. No guard work at all. No scrub, wheels fit fine.
- zossy1
Dundy2456 wrote:I have this size and offset. No guard work at all. No scrub, wheels fit fine.
A good sized pothole on heavy lock and you will crease your guard when the tread catches on the lip and unrolls it. Ask me how I know.
I had 15x8+25 on my NB, with 205/50/15 and it clipped the rear guards slightly.
hks_kansei wrote:I had 15x8+25 on my NB, with 205/50/15 and it clipped the rear guards slightly.
8a or 8b?
- Vehicle: Non MX-5
he has a 8a. but does it matter? same body aren't they?narita wrote:hks_kansei wrote:I had 15x8+25 on my NB, with 205/50/15 and it clipped the rear guards slightly.
8a or 8b?
- beavis
- Vehicle: NB8B - Turbo
8A and 8B are the same.
Rolling the guard lip is easy anyway.
Guard clearance is also gonna depend on ride height.
- zossy1
beavis wrote:8A and 8B are the same.
True, but who runs 15x8 +20 at standard ride height? Even at stock height, a good pothole with some decent steering lock and unrolled guards is asking for trouble.
Why not just roll the guards? It's not hard and if done right it won't even chip the paint.
zossy1 wrote:Dundy2456 wrote:I have this size and offset. No guard work at all. No scrub, wheels fit fine.
How do you know? haha (kidding). A good sized pothole on heavy lock for any car (that is as roadster-y as the mx5) is bad news :p I do my best to avoid them!
- Vehicle: Non MX-5
jeez how fast you going at full lock when hitting a pothole to cause damage?
i cannot do more than 15kph at full lock.
project.r.racing wrote:he has a 8a. but does it matter? same body aren't they?narita wrote:hks_kansei wrote:I had 15x8+25 on my NB, with 205/50/15 and it clipped the rear guards slightly.
8a or 8b?
i was more so wondering if he had 15's on a 8b since the brakes are bigger.
Users browsing this forum: No registered users and 204 guests
