Winmax W5 (Front) Brake Pads
Posted: Sun Apr 27, 2014 7:37 pm
As previously mentioned I have opted to try the Winmax W5's on the Front and the W3's on the rear.
The pads have been supplied by Marty Beckton (Motorsport Brakes Pty Ltd, Gold Coast) 0404 023 535 (marty@motorsportbrakes.com.au) and can be purchased through Automotive Plus.
At the moment I have only installed the W5's on the front as a rear caliper has a dodgy adjustment screw and if it plays up there are no spares available. As a side note I have another set on NB8B calipers being rebuilt as a spare. The rears still have the A1RM's installed for the moment.
Being in Blackwater there is nobody close by that can machine slotted rotors, so decided to do as suggested on the forum and give them a good sand down with 120 then 240 grit emery paper.
From one disc
This was washed off a disc (Brake cleaner)
The one on the right has been sanded, left one is untouched. Theses slotted rotors had Green Stuff pads on when last used.
The pads
Compound: Metallic
Friction: 0.40 – 0.43 μ
Temperature: 100 -750°c
A1RM and W5's. Note the chamfer and the slot in the middle to help release the vapours the pad produces.
A1RM's after a few track days
Pad install. A small mechanics stool makes a great caliper stand. Can anybody pick up my error in this photo?
Off topic but this is how much of the spring that is uncaptive at full droop
Bedding in. This is the last test. 10 runs at 80k to 20k every 500m, then 10 at 120 to 80 every 500m then 10 at 120 to 20 every 500m. After the last test and coasting down to a stop the rotor was at 310 deg c temp so hopefully I did it right!
As the test went along the brakes got better and better. Very responsive and heaps of initial bite on the last few tests, very good modulation and feel. The only bit of lock I got was at 29.74 on the picture hence the brake pressure reducing. I will find out in the morning what they are like cold and give some feedback on what they are like if you were to use them on a daily. The car now has its FZ201's on in readiness for Time Attack round 2
The yellow line (measure) is the TPS that I finally got around to wiring up. Instead of tapping into the existing TPS the Jenvey ITB's allow two TPS's so I installed the second one and now have it being logged.
From one disc
The pads
Compound: Metallic
