What size tyres?
15 x 8 +36 is very common and with 205/50 or 225/45 fits although some need to roll guards depending on ride height so offset will be fine.
Q? : 8inch wide rims with a +35 offset
- Jeo
Re: Q? : 8inch wide rims with a +35 offset
As above - wheels will fit, but whether the tyres do is entirely dependent on what tyres you run and exactly how low it is.
- Vehicle: ND - RF
Well the SE, which was the only model to have 17" wheels fitted standard, had 17x7 with a 40 offset and had 205/40 tyres.
So your option would have rims ~25mm wider with a 5mm greater offset, so.... the rim itself would poke out 5mm more but intrude 20mm further in although I get impression you understand this already.
What does this mean?
The biggest issue I think you may encounter would be clearance inside having dropped by ~40mm and poking 20mm further inwards into the wheel well.
Whether you would get rubbing is uncertain until you try it but tyre size would also play a role.
I think tyres wider than 205/40 would be appropriate on an 8" rim but you'd have to look at something like a 225/35 to maintain rolling diameter and a taller profile (40 or 45) would cause further issues with rubbing.
In all honesty I suspect even standard size tyres would struggle with that much drop!
Without actually trying it I would look at a bit more offset (add a 5 or 10mm spacer), lift the car a bit and possibly roll the guards and you should be ok.
It all come down to what you are trying to achieve?
- stance? -> more offset + heavy guard rolling + extra camber
- track? -> raise + roll + smaller rims and different brakes
- handling? -> see track
^^^^ Your calculations are off.
he would have 8mm less inside clearance and 18 mm more extension on the outside than a stock SE setup.
also a spacer would reduce offset.
i assume you have 17s at the moment?? whats size tyre? What offset? are they the stock SE 17s??
- Vehicle: ND - RF
Oops!
Yep, I've not no idea, don't mind me.....
And yes, at this stage I've still got all factory wheels & suspension on my SE -> 205/40-17 on 17x7 +40 rims
