? Intermittent brake noise in reverse ?
aviper4u
Postby aviper4u » Tue Apr 22, 2014 10:04 pm
Hello,
I have an NB8B with 114 kms completely stock apart from coilovers.
Issue occurs intermittently though it's hard to explain i'll give it a crack.......
So say you're in a carpark you find a sweet spot and start to back in and as you're creeping in you just touch the brake pedal and a vibration coupled by a noise occurs (non metallic).
This never happens reversing out of my driveway though :?
Anyone else have this occur?
Re: ? Intermittent brake noise in reverse ?
Postby Regie » Wed Apr 23, 2014 9:45 am
much meat left on the pads? might be down to the wear indicators
kalt
Postby kalt » Wed Apr 23, 2014 10:51 am
I've had a similar sound, in neutral allowing gravity/slope/momentum to roll the car back into a parking spot - loud krrrnnnk noise sounded and felt like I gutter rashed my rims, but didn't.
Doesn't occur if I slip into reverse gear, can be avoided if I slip into reverse.
Owning a fast car is easier than driving a car, fast.
For sale
NB8 Factory Airbox
