NA6 Wheel Alignment
Tumbles
NA6 Wheel Alignment
Postby Tumbles » Sat Apr 19, 2014 3:15 am
So, I got 195/50/R15 tyres put on 15x7 wheels. I'm currently still on stock suspension.
What sort of alignment figures would be best for spirited street driving? I've always worn the outside of my tyre, so negative camber is probably a must.
I was also thinking about some toe in on the rear to keep some higher speed stability.
Let me know if I'm on the right track?
I guess this is my signature.
Guran
Vehicle: ND - 1.5
Re: NA6 Wheel Alignment
Postby Guran » Sat Apr 19, 2014 8:27 am
Zero toe front & rear, max caster, about -1deg camber front and -2deg camber rear. Enjoy!
noobee
Postby noobee » Sat Apr 19, 2014 8:32 am
sailaholic
Postby sailaholic » Sat Apr 19, 2014 9:11 am
The lanny alignment (more rear camber then front) promotes understeer at the limit.
Fat cat say you should run more camber in the front then rear. Have a read here.
http://forum.miata.net/vb/showthread.php?t=340198
Also worth reading here. http://949racing.com/miata-race-alignment-info.aspx there is a street alignment as well as race.
Guran
Vehicle: ND - 1.5
Postby Guran » Sat Apr 19, 2014 9:36 am
sailaholic wrote:The lanny alignment (more rear camber then front) promotes understeer at the limit.
After using my alignment settings for the last five years of supersprints, I've never experienced issues with too much understeer at the limit. If you experience too much understeer with these settings on standard NA suspension, then you're just asking too much of entry speed and need to adjust your technique.
kazama
Postby kazama » Sat Apr 19, 2014 1:18 pm
what tyres are you getting for it?
with stock suspension id suggest same camber front and back, maybe try -1.8degrees. max castor after camber is set. 0 toe front. 1.6mm total toe rear.
use that as a starting point and go from there :)
edit: you probably wont be able to hit that front camber on stock height so get as much as you can so that all 4 remain equal imho
Tumbles
Postby Tumbles » Mon Apr 21, 2014 4:05 am
kazama wrote:what tyres are you getting for it?
Hankook Ventus S1 Evo in 195/50/R15 on a 15x7 Enkei 92 (6.21kg) +38 offset wheel.
http://www.tyrereviews.co.uk/Tyre-Type/ ... nce-Tyres/
Around about 20th on that list?
sailaholic
Postby sailaholic » Mon Apr 21, 2014 7:23 am
The list looks abit old. The Bridgestone grid 3 was replaced by the re001 which has been replaced by the re002. I first bought grid III 9? Years ago
Tumbles
Postby Tumbles » Mon Apr 21, 2014 3:27 pm
sailaholic wrote:The list looks abit old. The Bridgestone grid 3 was replaced by the re001 which has been replaced by the re002. I first bought grid III 9? Years ago
I think it just keeps results and ratings over time. Allows for comparisons between new and old tyres I suppose.
I just used it to give an indication of where the tyre sits in the "grip hierarchy" of street tyres.
Users browsing this forum: No registered users and 179 guests
