NA: Aftermarket tie rod
mitch_f1
Postby mitch_f1 » Tue Apr 01, 2014 10:04 pm
Hello,
So I bought an aftermarket tie rod for my NA6 from Repco of the TRW brand. I have been assured that it is the right one by the sales rep. However, I went to install it today, and found two differences, first that the ball joint is of a different style (probably not a big issue), but mainly, the threaded section appears to be shorter. Is this going to be an issue? Have I got the right one? Has anyone had a similar issue?
sailaholic
Re: NA: Aftermarket tie rod
Postby sailaholic » Tue Apr 01, 2014 10:33 pm
What rack do you have manual or power steer?
mitch_f1
Postby mitch_f1 » Tue Apr 01, 2014 10:34 pm
Power steering
mitch_f1
Postby mitch_f1 » Thu Apr 03, 2014 5:54 pm
no-one?
mitch_f1
Postby mitch_f1 » Sat Apr 12, 2014 5:46 pm
For the record, it is in and aligned correctly. Has a different sized nut, which is annoying cause I only realised after putting it back together.
