they are a hub kit
if you can source some RX8 hubs, they bolt straight up and are much stronger
2007 NC Front Wheel Bearings
- Regie
- Vehicle: NC - V8
Re: 2007 NC Front Wheel Bearings
- Charlie Brown
As Regie said, get the RX-8 hub but it must be the later model RX-8 after 2009 for the ABS sensor connection to match.
The hub is a full sealed unit so you can't change the bearings and from personal experience, DON'T get an after market hub. I had ABS and fitment problems with the two I tried.
Read all about it in this post: viewtopic.php?f=79&t=60644
