Suspension help please
Posted: Thu Dec 19, 2013 8:24 am
by giordy
So i had my car on bricks while doing some work decided to lower the coilovers all the way down and drove off and was a slight bang when i drove of when i got out and looked the front left is noticabley lower than the right hand front can someone tell me what happened did i ƒü¢k the coilover or ? Could it be a flat tyre or ? Please help
Re: Suspension help please
Posted: Thu Dec 19, 2013 9:19 am
by Magpie
Flat tyre should be obvious as the tyre is no longer round!
What coilovers? Sway bars, endlinks etc?
Posted: Thu Dec 19, 2013 9:33 am
by hks_kansei
If you can't tell if a tyre is flat by looking at it, then you shouldn't be touching anything related to suspension or brakes.
Low on pressure is hard to spot by eye (ie: within 5-10psi) but flat is as obvious as day or night.
Anyway, the clunk could be anything
is there a brick under the car still?
is it low enough to be touching the ground?
Are the springs still captive? (on extension)
As for the height difference:
Did you measure each side (threads on the coil)
Did you maybe wind the perch low enough that it has come off the threads (I'd assume though that coilovers would have a stopper there to prevent this...)
