Rear suspension knock
- dmad_dood
First off i've done a search and didn't find much in the likes of helping my issue so hear i am,
I changed the suspension on my car and then did a wheel alignment a while back but i'm getting a knock from the rear left. Ive tried just about everything i can think of to remedy the situation like moving the exhaust, reinstalling the coilovers, checking over the bolts 30 times, checking clearances etc..
its been like this for a few months now and happened as soon as i changed my coilovers over.
The noise only happens when driving over small bumps and bigger, the noise gets worse in successive bumps. It also makes the car jump slightly. Could i maybe be an issue with the coilover itself?
Im all out of ideas, can anyone help?
Jono.
Jono.
Red NA8..
- Regie
- Vehicle: NC - V8
Re: Rear suspension knock
disconnect one of the sway bar end links and take it for a drive.
if the knock disappears, the bearings in the end links are stuffed.
This happened to my NB a few years ago
- dmad_dood
Regie wrote:disconnect one of the sway bar end links and take it for a drive.
Ill give that a go, its worth a try. Thanks
Jono.
Red NA8..
What sort of wheels are on it?
They tyres may be lightly clipping the guards if they're wide/low offset.
Perhaps after the alignment/coilovers (height change?) they now clip (less negative camber maybe?)
Also check easy stuff like making sure the spare tyre and battery are clamped down firmly.
- dmad_dood
hks_kansei wrote:What sort of wheels are on it?
Ive got plenty of clearance in the guards and my wheels are very close to stock offset so i can rule that out, ive also checked the spare tyre, battery and jack to make sure there not moving around.
Red NA8..
Check that the nut on the top of the shock shaft is tight.
Rob
- dmad_dood
I remember trying to tighten that a while back but I think everything just span if I remember correctly and I wasn't sure how tight it should of been either
Red NA8..
- PT
I had the same thing when I installed coil overs and then had a wheel alignment done. The eccentric bolts need to be very very tight. If they are not tight enough you will get a knock that sounds like there is something loose in the boot. Like metal on metal sound.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
- dmad_dood
Thats the sound. Like a sort of dull thud metal on metal sound?
Now which are the eccentric bolts? The bolts that to through the bottom of the coilover?
Red NA8..
- aka_juffa
dmad_dood wrote:Thats the sound. Like a sort of dull thud metal on metal sound?
There are 4 eccentric bolts at each end the car, two on each side. they are the bolts that have a large washer with markings.
I've another suggestion for the noise. Between the suspension top hat and the car body there should be a very thin piece of plastic. that plastic stops metal to metal contact. Do you remember installing the plastic when you did the dampers?
J
- dmad_dood
aka_juffa wrote:dmad_dood wrote:Thats the sound. Like a sort of dull thud metal on metal sound?
J
I did put the plastic spacer on top, i made sure of that.
I no the bolts your talking about but I didnt touch them when i installed the suspension but ill give them a once over in case.
Red NA8..
- aka_juffa
You might not have touched them, but they would have been adjusted for the wheel alignment.
J
J
- dmad_dood
aka_juffa wrote:You might not have touched them, but they would have been adjusted for the wheel alignment.
J
The wheel alignment was done over a month after the suspension instal. And as soon an i installed the coilovers the noise was happening.
I will still give it a try thou.
Red NA8..
- Vehicle: NA6 - Turbo
Have a look at the sway bar and the coil spring
sometimes the sway bar can slide sideways and touch the coil
Olboy
Olboy
the strut top nut may be loose. Take an ring spanner and torque it down some more. The weight of the car will hopefully not cause the strut shaft itself to turn when your doing this.
