12 & 6 wobble that is not hub.
KeeFy
Postby KeeFy » Fri Nov 08, 2013 10:37 pm
Hi Guys, I've been searching the forums with no avail.
I hit a pothole coming round a bend and something gave. Doing the 12 & 6 check, there is some slight movement and I've replaced the hub only to find it's NOT it. :(
Problem is i can't seem to pin point the knocking noise when shaking the wheel at 12 & 6. I can't feel or see anything else moving.
Any tips? Thanks in advance.
project.r.racing
Re: 12 & 6 wobble that is not hub.
Postby project.r.racing » Sat Nov 09, 2013 12:07 pm
steering arms
tie rod ends
a arm bushes
Guran
Vehicle: ND - 1.5
Postby Guran » Sat Nov 09, 2013 5:20 pm
Had the same movement in mine until recently. Replaced wheel bearings (they were growling loudly) and lower control arm ball joints ... problem solved.
mitch_f1
Postby mitch_f1 » Sat Nov 09, 2013 6:15 pm
I have a similar wobble. I believe it to be inner tie rod end, which has not yet been replaced.
KeeFy
Postby KeeFy » Sat Nov 09, 2013 9:57 pm
Thanks for the replies.
If i'm not wrong, tie rod would show at the 9 & 3 mark, but there is no noise at 9 & 3. Only at 12 & 3.
I thought it was lower ball joint as well, but i don't feel any play in it. I really should go buy a pry bar and double check it.
Or maybe i'll just have a go and change that as well.... hopefully that will fix it up.
Thanks guys! :)
Users browsing this forum: No registered users and 362 guests
