Hit pothole - 2 damaged original wheels on NB 1998 - advice?
aSimpleLife
Postby aSimpleLife » Sat Oct 19, 2013 5:13 pm
Sorry for creating a new post, but can't seem to find the advice I was looking for.
Sadly I've hit a pothole and bent both wheels on the passengers side.
Even more sad is I'd recently purchased a new set of RE002's (195/50R15), less than a 1,000km's and one if not both are stuffed as well.
So after 30 years of driving, in the nicest car I've ever owned (original, low km, 1 owner), running the most expensive tyres I've ever bought, I've done this for the first time...what a loser :(
I'm surprised at the damage I did, at about 80kmh on a sweeping bend, but it did hit hard, and jarred loose the passenger side the soft top roof clamp.
First question is, am I likely to have damaged more than just the wheels?
And how will I know?
Secondly, am trying to decide if I replace the 2 wheels, or buy a new set of wheels?
It's a very original car and I hadn't been planning to modify it all.
Assume if I stick with the original wheels it'll keep the cars value more?
Either way, any suggestions on best way to source either replacement or new wheels? (haven't done either before)
I'm in Melbourne out East. Can travel (in the other vehicle :)
Thanks in advance for any help/guidance.
Kuncha
Re: Hit pothole - 2 damaged original wheels on NB 1998 - adv
Postby Kuncha » Sat Oct 19, 2013 5:43 pm
You can repair the wheels if you wish.
aSimpleLife
Postby aSimpleLife » Sat Oct 19, 2013 6:03 pm
Thanks very much for the response.
My tyre place had told me I couldn't...so that was all I had to go by.
Can you suggest anywhere?
I'll start my search again for that now thanks.
aSimpleLife
Postby aSimpleLife » Sat Oct 19, 2013 6:16 pm
OK, found this thread and looks like Neway Wheel Repairs in Heidelberg West, Melbourne VIC could be worth a shot at around $80 each.
http://www.newaywheelrepairs.com.au/profile.html
Thanks again for putting me on another track.
http://mx5cartalk.com/forum/viewtopic.php?f=30&t=57306&p=722176&hilit=repair+wheel#p722176
zero00
Postby zero00 » Sat Oct 19, 2013 7:34 pm
Don't feel too bad, the BEST car I ever owned before the MX5 was a Lexus IS200 Sports Luxury - one large pothole, splayed the front end and creased the roof in FOUR places! It was raining, you could not see the pothole yet the Shire effectively said 'Your problem'
When I rang them that night and asked them to close the road before someone was in injured or worse, it was a flippant 'No'. If a Suzuki 4x4 had hit the same hell knows what would have happened
All the best and I hope you get it sorted
Roger D-SUNSHINE COAST
Locutus
Postby Locutus » Sat Oct 19, 2013 7:57 pm
If your new tyres were fitted by Bridgestone, you should be covered under their road hazard warranty.
Kuncha
Postby Kuncha » Sat Oct 19, 2013 8:10 pm
I have used these guys before.
http://wheeltechwheels.com.au/
Postby bruce » Sat Oct 19, 2013 9:13 pm
Probably cheaper to buy a new pair of original rims.
Up your tire pressures to avoid damage.
aSimpleLife
Postby aSimpleLife » Sat Oct 19, 2013 9:35 pm
Locutus wrote:If your new tyres were fitted by Bridgestone, you should be covered under their road hazard warranty.
Thanks very much for the heads up on that. They were fitted at Bridgestone. And they have less than 10% wear.
But according to the terms and conditions I had to fill in this warranty at time of purchase - which I didn't.
"Please enquire in store to arrange your Safe Drive Warranty.
(Must be Authorised by the Store upon sale)"
I'll give it a shot Monday anyway.
aSimpleLife
Postby aSimpleLife » Sat Oct 19, 2013 9:40 pm
zero00 wrote:Don't feel too bad...
Well it was raining...and it was dark...and it was late I wasn't concentrating as hard as I could have...so only have myself to blame.
Am tossing up trying the council...the tyre place said several claims have been successful recently...if over $1000?...but maybe they were just trying to distract me from the Bridgestone Safe Drive Warranty :)
Thanks for the kind words...but I'm still a loser though :)
aSimpleLife
Postby aSimpleLife » Sat Oct 19, 2013 9:44 pm
Kuncha wrote:I have used these guys before.
Thankyou. I'll follow them up too.
aSimpleLife
Postby aSimpleLife » Sat Oct 19, 2013 9:46 pm
bruce wrote:Probably cheaper to buy a new pair of original rims.
As in contact Mazda for replacement rims from 1998? Sorry if I'm missing something obvious.
bruce wrote:Up your tire pressures to avoid damage.
I had them on 35psi. Should I have them higher than that?
Thankyou.
JBT
Postby JBT » Sat Oct 19, 2013 10:39 pm
You may be able to pick up a couple of straight used NB wheels that someone no longer wanted. 36 psi is far to high IMO anyway. any higher will shake your teeth out.
zero00
Postby zero00 » Sat Oct 19, 2013 11:15 pm
JBT wrote:You may be able to pick up a couple of straight used NB wheels that someone no longer wanted. 36 psi is far to high IMO anyway. any higher will shake your teeth out.
That's all good JBT, if that happens I've box a special felt lined box to put them in! Just don't smile at people passing by!
With the KU36's, Option 1 Garage suggested 34psi as a minimum .. with mine they both certainly do not feel 'hard' on the road and the NB handles perfectly on the track :wink:
I used to run 40psi in my Corolla Sportivo normal driving and on a trip 42psi - that was the recommended
davekmoore
Postby davekmoore » Sat Oct 19, 2013 11:43 pm
That a council might ignore or refuse a claim doesn't necessarily mean there is no claim. Ir merely means they ignored or refused that particular claim.
Users browsing this forum: No registered users and 316 guests
