rx7 brakes
itbmiata
rx7 brakes
Postby itbmiata » Thu Oct 03, 2013 11:35 pm
just want to know if there is a thread on fitting up rx7 fd or fc brake calipers to a na6
sailaholic
Re: rx7 brakes
Postby sailaholic » Fri Oct 04, 2013 7:11 am
Not on here I don't think, there is on the web though.
Sent from my iPhone using Tapatalk - now Free
mazmad
Re: rx7 brakes
Postby mazmad » Fri Oct 04, 2013 7:55 am
How you don't mind if I borrow your thread for a moment... :D
Is there a need for it? Na's ran smaller brakes than the nb's right? The nb and nc have enough braking from what I can see. Has anybody needed to increase rotor size on them for track?
ja9
Re: rx7 brakes
Postby ja9 » Fri Oct 04, 2013 8:00 pm
No I certainly didn't need to. I ran TWR pads on stock calipers but rotors were slotted. The car had excellent brakes, never had fade and I loved them. The pads were also relatively cheap at $70 per set. How could you go wrong. They were brilliant. Run some fresh brake fluid through the system and save your money.
Actually buy the TWR pads first and try them. If you don't like them then you're out of pocket by $70. My bet is you'll thank me for saving you some money but I'm guessing you've already bought the calipers.
Regards - John
UNDERSTEER is when you hit the wall with the front of the car. OVERSTEER is when you hit the wall with the rear of the car.
Re: rx7 brakes
Postby Okibi » Fri Oct 04, 2013 9:39 pm
spikey had some on his car, you could try message him.
itbmiata
Re: rx7 brakes
Postby itbmiata » Sat Oct 05, 2013 11:47 am
Already running nb calipers n TRW pad with DBA slotted disc n n they r OK soon will have a lot more power n will be tracking the car. Would not use TRW again as they leave way to much brake dust
ja9
Re: rx7 brakes
Postby ja9 » Sat Oct 05, 2013 3:49 pm
Forgot to mention my car was an NA6 and a race car. Yes they do produce a good amount of brake dust. What you should know is they have a working temperature of up to 600 degrees C, so I'm guessing they wouldn't be that good on the road. When they warmed up on the track they were more than adequate. First lap was ordinary so I can understand your comment about them being ok. I doubt you would get the necessary temp for them to come on to temp on the street.
Good luck with whatever you choose to do as good brakes inspire confidence and ultimately faster lap times.
For what it's worth I'm running Hawk Blue 9012 on my new car (NB8A) and love them.
- John
sailaholic
Re: rx7 brakes
Postby sailaholic » Sat Oct 05, 2013 6:59 pm
itbmiata wrote:Already running nb calipers n TRW pad with DBA slotted disc n n they r OK soon will have a lot more power n will be tracking the car. Would not use TRW again as they leave way to much brake dust
Which nb brakes nba or NBb? I assume you have itbs? If so I'd be very surprised if you need more brakes then nbb without a turbo.
mazmad
Re: rx7 brakes
Postby mazmad » Sat Oct 05, 2013 8:36 pm
Yeah agreed sailaholic. One of the first upgrades I was going to do to my car was brakes, luckily I was talked out of it (one of the many gems of wisdom i was given along the way). All I have done is braided lines and non standard calipers and pads.
Re: rx7 brakes
Postby Magpie » Sat Oct 05, 2013 8:52 pm
If anything look at getting some air ducted into your front brakes, keeping them cool on the track will help reduce fade.
itbmiata
Re: rx7 brakes
Postby itbmiata » Mon Oct 07, 2013 3:32 pm
Magpie wrote:If anything look at getting some air ducted into your front brakes, keeping them cool on the track will help reduce fade.
thanks will look in to it
itbmiata
Re: rx7 brakes
Postby itbmiata » Mon Oct 07, 2013 3:35 pm
Which nb brakes nba or NBb? I assume you have itbs? If so I'd be very surprised if you need more brakes then nbb without a turbo. - now Free
they r nbb set up
