Running Federal 595 RS-R in opposite direction
ljs18
Postby ljs18 » Thu Sep 05, 2013 8:46 pm
Has anyone run Federal 595 in opposite direction? Any problems?
Thanks
Re: Running Federal 595 RS-R in opposite direction
Postby NitroDann » Thu Sep 05, 2013 9:00 pm
They won't work at all whatsoever in standing water.
Juicy HiC
Postby Juicy HiC » Thu Sep 05, 2013 9:24 pm
Why?
ljs18
Postby ljs18 » Thu Sep 05, 2013 9:45 pm
I would not run them in the wet as the water channelling properties of a directional tyre are lost. However QR and Lakeside are clockwise an I thought to give the outer edge of the inner tyres a scrub before I get them turned on the rim. The weather looks fine for the weekend. I run 3degrees of negative camber front and rear and still wear the outside of the tyres.
Thanks
MINX
Postby MINX » Thu Sep 05, 2013 10:17 pm
ljs18
I assume they would respond similarly to my Hankook RS-3s
I recently ran them at Lakeside - 'backwards', in the dry.
No problem at all.
First lap and a half after running them the correct way for 18mths, they were a bit rumbly, like they had a bit of pick up.
After that they came good and I ran PB laps in 63s at LS.
I didnt crash and die once.
Mine were suffering from too many right hand turns.
I will be running them 'backwards' at QR on Monday aswell. Assuming dry conditions.
Stu
deviant
Postby deviant » Thu Sep 05, 2013 10:42 pm
The tread pattern is designed to force water away from the centre of the tyre and 'squirt' it out of the sides so don't run them in the wet.
Dry track use...go for it.
corners
Vehicle: ND - Supercharged
Postby corners » Fri Sep 06, 2013 2:24 pm
MINX wrote:I didnt crash and die once.
:lol: :lol: :lol:
project.r.racing
Postby project.r.racing » Sat Sep 07, 2013 8:23 am
:lol: :lol: :lol:
Yeah. If you die twice, that's when the problems really start. :lol: :lol: :lol:
ljs18
Postby ljs18 » Sun Sep 08, 2013 9:50 am
Good news is that I didn't crash and die once. Bad news is that the car was very unsettled under brakes, 2secs down in lap times. So from my experience it doesn't work with 595s.
project.r.racing
Postby project.r.racing » Sun Sep 08, 2013 12:33 pm
so only run the rears in opposite dirction?
ljs18
Postby ljs18 » Sun Sep 08, 2013 12:58 pm
project.r.racing wrote:so only run the rears in opposite dirction?
Might try that on a midweek sprint.
zero00
Postby zero00 » Sun Sep 08, 2013 5:24 pm
ljs18 wrote:Good news is that I didn't crash and die once. Bad news is that the car was very unsettled under brakes, 2secs down in lap times. So from my experience it doesn't work with 595s.
As your times would be if they were in the morning!! 38 cars in ONE group? QR has an IT issue so Natsoft hasn't been updated
If it was in the Sprints in the afternoon then hmmmm .. back to 'Plan A'
Roger D-SUNSHINE COAST
Users browsing this forum: No registered users and 143 guests
