mx5 le (or R package) track rod end
Rasco
Postby Rasco » Tue Aug 06, 2013 9:45 pm
I give up, who has the link where I can buy these from?
sailaholic
Re: mx5 le (or R package) track rod end
Postby sailaholic » Tue Aug 06, 2013 9:48 pm
Tried miata roadster?
Postby 93_Clubman » Wed Aug 07, 2013 12:08 pm
If not already seen, may be some info in this that might help:
viewtopic.php?f=30&t=43382
Rasco
Postby Rasco » Wed Aug 07, 2013 4:07 pm
thanks guys, it seems a bit of a murky area but threw the persistence of checking different descriptions I've found the below two links, which seem to be the applicable part
http://www.miataroadster.com/mazda/mazd ... 12314.aspx
http://www.v8roadsters.com/product-p/bp-strk.htm (gulp expensive)
I'm not smart enough to figure out if the below is OK for my lowered beastie
http://www.mx5parts.co.uk/track-genuine ... p-495.html
myredmx5
Postby myredmx5 » Thu Aug 08, 2013 9:47 am
PM sent
Postby 93_Clubman » Thu Aug 08, 2013 11:45 am
Rasco wrote:I'm not smart enough to figure out if the below is OK for my lowered beastie
MX5 Parts one sounds like it's the standard version, ie non- US '93 LE or R Package version. Think you'll find that many that have lowered have not changed from the standard version. So MX5 Parts version would be useable, but you may find some benefit from the Miata Roadster ones linked above. May be ask MX5 Parts if they have the US '93 LE or R Package version? However, note UK didn't get the R Package/ Clubman, or the US '93 LE that used these different tie rod ends due to having Bilsteins fitted. UK did get a '93 SE, which didn't sound like it had Bilsteins fitted. Indeed, don't believe even the '93 LE we got had Bilsteins fitted.
Tks for the Miata Roadster link above - I'll put it into the Clubman FAQ.
