Sway bar mount braces
Sailor
Postby Sailor » Tue Jul 16, 2013 9:31 am
These popped up on the Goodwin site.
Looks like a good thing for early models to prevent that sway bar mount failure
http://www.good-win-racing.com/Mazda-Pe ... urce=News1
Rob
deviant
Re: Sway bar mount braces
Postby deviant » Tue Jul 16, 2013 10:36 am
I saw these in my email this morning to :D
I always knew that the sway bar mounts flexed somewhat but it is still fascinating to see by how much. I would love to know how this affects roll rates and stiffness.
I am guessing that these blocks are just forced against the chassis rail and the white cross brace is to stop them twisting sideways and out of place?
Sailor
Postby Sailor » Tue Jul 16, 2013 10:57 am
Looking at the flex without the brace, I'd guess a softer bar could be used once the brace is installed.
Rob
Postby Okibi » Tue Jul 16, 2013 8:23 pm
I have had one of these braces for a few years after buying them off Lou, the brace didnt fit on the SE but I kept those hunks of metal and long bolts. They can be a bit of a PITA to install but i'd recommend them.
zorak
Postby zorak » Wed Jul 17, 2013 4:18 pm
wow never knew there was so much flex under there either
better get under the car to see that my chassis mounts haven't already cracked
NB8A
WP 1:10.69
SMSP (south) 1:04.41
SMSP (GP) 1:53.98
Postby Magpie » Wed Jul 17, 2013 4:25 pm
Other sway bar mounts (at the bottom of the page) http://www.iscracing.net/miatasuspension.html
Postby Lokiel » Wed Jul 17, 2013 5:18 pm
Okibi wrote:I have had one of these braces for a few years after buying them off Lou, the brace didnt fit on the SE but I kept those hunks of metal and long bolts. They can be a bit of a PITA to install but i'd recommend them.
You sure they won't fit?
I have a set on my car (see http://mx5cartalk.com/forum/viewtopic.php?f=57&t=41091&hilit=sway+bar&start=26) and so does MINX.
For those wondering why these are useful, see http://mx5cartalk.com/forum/viewtopic.php?f=30&t=51957&p=653170&hilit=yeah#p653170
Postby Okibi » Wed Jul 17, 2013 6:21 pm
Lokiel wrote:..You sure they won't fit?..
These fit
http://www.racingbeat.com/Miata-1990-2005/Sway-Bars/54123.html
But I didnt fit this
http://www.racingbeat.com/Miata-1990-2005/Sway-Bars/54121.html
Can't remember if the pipes got in the way or I thought it wouldn't fit when I put in a larger radiator.
Postby Lokiel » Wed Jul 17, 2013 6:47 pm
Ah, makes sense now - when I bought mine, Brian just recommended the first one.
