Suspension and aero question(s)
Posted: Fri Apr 26, 2013 2:19 pm
When people have been doing aero (splitter/wing/diffuser/skirts) mods was any consideration given to the spring rates and/or other suspension components? If people did how did they arrive at the spring rates/other suspension modifications? Did the aero mods change understeer/oversteer characteristics and if so how were these managed? Was it through trial/error or a calculated/planned/ride heights?
I have noticed with my rear wing at the moment that at high speeds there is a very obvious lightening of the front end and at lower speeds (when accelerating after the apex of a corner) there is a bit of understeer (there is no splitter at the moment). It does have a very large angle of attack (15 deg) which in turn causes drag, however the wings’ effect at below say 80 kmh might not be the reason for the understeer. The rebound setting on the shocks is such that there is not an instantaneous transfer of weight from the front to the rear when accelerating out of a corner. Therefore as there is a progressive weight transfer from front to back the front tyres still should have grip so the main reason for the understeer is more than likely that there is no rear sway and not an effect from the aero. Note I’m putting the rear sway back on soon.
My concern is that, is it possible to use most of your suspension travel up through downforce alone and have little travel left for road conditions (especially at high speeds) if you don't consider your spring rates when building aero mods?
Aero mods is my next project/focus as my engine is now being built and I want to understand how it all works together.
